Results 1 to 5 of 5
Thread: Problem: NUMOSKTOVAR;VARAIBLE1||OSKTOVAR;VARIABLE2
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    I am having an issue with using the following
    NUMOSKTOVAR;VARAIBLE1||OSKTOVAR;VARIABLE2||SETVAR; VARIABLE3;TEST
    What is happening it doesnt wait for the numberosk to close before launching the OSK,
    How ever it does wait Until the OSK is closed before it executes any command after the OSK .
    How can I work around this problem.
    New Age Garmin - Skin for RR
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    try NUMOSKTOCMD
    NUMOSKTOCMD;VARAIBLE1;OSKTOVAR;VARIABLE2||SETVAR; VARIABLE3;TEST
    this will allow numosk to stay open , on hitting enter then the OSK will appear
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I ran into something like this a long time ago, I figured out that it didn't like them being on the same line.. even with the ||
    I have no idea why this is the case, but it worked for me. I cant remember how long, but I spent a LONG time till I got this to work!!!!!
    Put this in the exectbl.ini
    (Just make the button code in the skin "MakeVar1" of course)
    "MakeVar1","||NUMOSKTOCMD;VARAIBLE1;MakeVar2"
    "MakeVar2","||OSKTOCMD;Varialbe2"
    If you remove the || from the second line, it will not wait for the NumOSK entry before the OSK appears.
    This does not follow the syntax for the commands in the SkinCommands.txt, and there is no reason at all that it should work.... but this DOES. I just tested it here with the skin tool open, and both Variable1 and variable2 contain what was typed in the NumOSK and the OSK respectivly.
    My Fiero Build Thread
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    It must have worked.... a week later and no replies
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by carputer1
    try NUMOSKTOCMD
    The weird thing is that line does work via the SkinTool, but not when used in the exectbl file. Something must happen to it when it tries to tranlate it.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
