Results 1 to 4 of 4
Thread: What does RR do when embedding an application
    Nov 2006
    A couple of questions on RR and embedding:
    1. Does RR "scale" the target application window when it embeds the named application into the "Axx" area?
    2. If it does, what attributes must the target window have to be scaled?
    I've written a small application that, in order to embed properly, the apps window size apparently must match or be smaller than the "Axx" size. Must this be the case?
    Regards,
    Jim
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    #1 & 2
    If the application allows the window to be resized then yes, otherwise RR will just position the top left of the app window to your top left most starting pos def in the "A" line.
    If its not embedding:
    #1 You either don't have the correct window title specified when loading that screen
    #2 The form/window sizing/style property is set to not allow it to be resized
    #3 If above two don't fix it then you might need to give more details, eg what lang app is written in, ect.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Nov 2006
    I am using AutoIt scripting to create the window. AutoIt provides a GUICreate function that provides for the same parameters and styles that the Windows API provides.
    Specifically, what styles should I use to allow sizing when creating the window?
    I already have WS_MINIMIZEBOX, WS_MAXIMIXEBOX, and WS_SIZEBOX. Do I need others?
    Regards and Happy New Year,
    Jim
    Jun 2003
    Memphis - TN
    What do we do if the window title changes? Im trying to embed an explorer window and it un-embeds.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  1. Navigon Navigator 2.0 embedding in RR
    By osa2 in forum RR Skins
    Last Post: 01-07-2011, 05:22 AM
  2. problem embedding iguidance in RR
    By bangumandoo in forum Software & Software Development
    Last Post: 05-29-2007, 10:16 AM
  3. Replies: 12
    Last Post: 03-21-2007, 11:34 AM
  4. Replies: 5
    Last Post: 01-20-2007, 12:55 AM
  5. RR application launch
    By qseven in forum Software & Software Development
    Last Post: 03-29-2006, 09:29 AM
