Results 1 to 5 of 5
Thread: Some Questions Regarding Embedding External Apps
    Oct 2004
    Israel
    Hi
    Im using the embedding thing quite alot and I have some stuff I was wondering if possible
    1.To avoid flashing when clicking on buttons ( window focus issue ) I use clipping , However when I use "discardable" and "close" commands to kill the program when exiting the skin I get a couple of seconds of my desktop in the clipping area
    Is there any way of clipping the area without actually clipping the entire rr? so it will leave the static background intact?
    Or maybe a way to get back to the previous skin and then kill the app ( I tought of using an external kill but I don't really like workarounds like that ) without showing the desktop in the process?
    2.I'm embedding some apps that are movable by draging the window itself ( not just the title ) like dscaler
    So if I accidently drag my finger it moves the embedded app for a second and then move it back to the embedded area
    Is it possible to lock the app at its place or is it really up to the app i embed?
    3.Is there anyway to avoid clipping? It seems so low-tech..
    Thanks In Advance ,
    Madboy
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by [URL="http://www.mp3car.com/vbulletin/members/madboy.html"
    Madboy[/URL]]
    Because the discard scrn opt, you shouldn't need the close cmd, when it discards the screen when leaving it, it should also kill the embeded app that was loaded into that scrn
    Quote Originally Posted by [URL="http://www.mp3car.com/members/madboy.html"
    Madboy[/URL]]
    This sounds like you aren't using the correct window title to embed the app with as RR will check and reposition the embedded app on every screen update if needed. ~1/sec
    Madboy[/URL]]
    "Low-tech", yes. But for some apps is the only way to be able to use it within RR.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Oct 2004
    Israel
    I don't think it does then
    when i embed sygic i have 2 buttons which is "back" and "close"
    "back" leaves sygic open while "close" doesn't
    and i use discardable
    yeh it does reposition , thats not my problem
    i want it to not move at all
    isn't there a way to clip it but leave the background?
    from my understanding the whole thing happens when the rr and the embedded app are fighting each other for focus right?
    can't u just set the clipped area as static and not focus on it? like splicing the app to 2 apps and leave one un-focused?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by [B
    Blue ZX3[/B]]
    Quote Originally Posted by Madboy
    I did say "should" as I wasn't 100% sure and didn't check the code to see exactly what occurs.
    Blue ZX3[/B]]
    There is no way to "lock" the window into a position and still use it.
    Only other thing you could try is to set RR's window NOT on top and set the apps window on top. See the skin commands for the exact cmd name and usage. Look for 'ontop'
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Oct 2004
    Israel
    OK thanks man
    can you set the close command to first go back to the last skin and then kill the app at the background at the next rr release?
    i really want to avoid the couple of seconds which shows my desktop when i press close
  1. External HDD questions
    By FockMasterDan in forum General Hardware Discussion
    Last Post: 07-17-2008, 04:51 PM
  2. Embedding Apps
    By jgarth in forum Road Runner
    Last Post: 09-20-2006, 09:42 AM
  3. Embedding and OSK questions
    By DiNASTY in forum Road Runner
    Last Post: 05-29-2005, 06:02 PM
  4. Replies: 6
    Last Post: 05-25-2005, 12:53 PM
  5. 2 Embedding Questions
    By edrex in forum Road Runner
    Last Post: 05-11-2005, 06:13 PM
