Results 1 to 6 of 6
Thread: Close SpeedFan on RR exit
    Low Bitrate CherokeeChief's Avatar
    Nov 2004
    Italy
    I start Speedfan using the ONSKINSTART cmd in my execTBL.ini as follows:
    "ONSKINSTART","RUNQ;C:\Programmi\SpeedFan\speedfan .exe"
    It works great at RR startup, but I need to close it when I'll shut down RR to go in the Windows XP Desktop.
    I have tried several commands on the "Exit" button in my skin, i.e.; "EXIT||CLOSEWINDOW;SpeedFan" but doesn't work.
    I read also about ONSKINEND cmd, but I don't know the exact syntax and I ahave tried it in my execTBL.ini, but doesn't work.
    Any help is appreciated.
    Thanks.
    It's a Jeep thing...you wouldn't understand !--------------------------------------------
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Run RRConfig and look at the Embedded Aplication, make sure it is listed, if it is, it should terminate on RR exit.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You should use winspector spy or something similar to get the correct window title for speedfan, then the CLOSEWINDOW command should work. Just make sure that you use the command BEFORE the Exit command on your skin like this: "CLOSEWINDOW;SpeedFan||EXIT" -- remember to replace SpeedFan with the correct window title you got from Winspector spy.
    Ride Runner RR's Myspace
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by MGD View Post
    I Think, if memory serves correctly, anything listed there are programs that RR will NOT terminate. Such as if you were using iGuidance for instance, and have a route planned. Having "iGuidance" in the applications list tells not to kill it.
    This was implemented so you can change a background, font color ect, and issue the Reload RR command, and not have the program close, thus have to put your route and destination in all over again.
    My Fiero Build Thread
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I think that is correct as well. Do you have the close apps on exit set in the config
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Nov 2004
    Italy
    Quote Originally Posted by guino View Post
    Perfect..it works ! Thanks.
  1. Switching between RR and copilot
    By CombatCQB in forum Road Runner
    Last Post: 01-26-2009, 05:27 PM
  2. RR is acting really slow... debug.txt attached
    By ludikris in forum Road Runner
    Last Post: 04-11-2008, 12:35 PM
  3. Replies: 7
    Last Post: 07-21-2007, 12:14 AM
  4. Set RR to close a program ... not hide
    By drPheta in forum Road Runner
    Last Post: 08-23-2006, 10:19 PM
  5. RR doesn't close Iguidance.exe
    By NRGZ28 in forum Road Runner
    Last Post: 03-04-2006, 05:32 PM
