Results 1 to 6 of 6
Thread: Wrong screen loading - winamp pl disappears
    Low Bitrate jparks27's Avatar
    Feb 2006
    Maryland
    I updated to the December release after uninstalling the previous ver.
    Then the problems started...
    Running DX4 skin..
    Winamp will not keep a playlist.. I can set a playlist, and when you launch RR it removes EVERYTHING from that playlist... I can load a playlist in RR, shut it down, and restart it, and poof, it's empty again...
    I also had an issue where the first menu screen displayed the speedo correctly, but the second menu screen did not... the top and bottom portin isnt there, only center.
    I am running a Dell Studio Hybrid, 3GB DDR2, T6400, 250gb hd.. 800x600 4:3... running XP pro..
    I then installed an application I shouldn't have, and it borked my computer, so I installed 7 Ultimate..
    Got everything set back up, as far as TS drivers, DX4, iG, etc etc... double and triplechecked my config, and everything is as it should be..
    STILL having an issue with not saving playlist/keeping playlist, even though it worked perfectly in the previous release.. STILL having an issue with the top and bottom of the speedo on the second menu screen not appearing correctly (at all, really)..
    And now.. Here's even screwier...
    I try to launch GPS either from main menu or from the music screen, and it launches the 'themes' menu (where you choose color theme) and then locks up..
    Whiskey Tango Foxtrot, over.
    I have double checked that the link is correct in setup and in the .ini....
    I have not tried the 1/1 release...
    Feb 2006
    Maryland
    Really? Nothing?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Please make a debug log -- and if you don't use Phonecontrol.net or mapmonkey, I highly suggest you try 1/1/10, then make a debug log if you still have the same issues.
    Ride Runner RR's Myspace
    MySQL Error
    Oct 2004
    jparks, you did remove the kill winamp from dx4 right?
    and
    you got the updated files from the DX4 thread right?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Feb 2006
    Maryland
    kill winamp from DX4 did the trick, reinstalling killed the mapping issues...
    Weird how an install would corrupt all by itself, but it's working now..
    MySQL Error
    Oct 2004
    i dont see how an install (of riderunner) get corrupts
    unless a file was inuse, but the installer would have told you during the install
    Dx4 is a massive skin, and does need a update
    i always say when in doubt try it on carwings
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 12:46 PM
  2. Archive
    By Bitoholic in forum Mobile Media Center
    Last Post: 09-21-2006, 05:59 PM
  3. Spectrum Analyzer Winamp Visualization, Full Screen anyone??
    By J187 in forum Software & Software Development
    Last Post: 06-09-2005, 06:31 PM
  4. full screen winamp
    By djmickyg in forum Software & Software Development
    Last Post: 03-25-2004, 06:59 AM
  5. winamp screen position
    By jstrain in forum Off Topic
    Last Post: 05-12-2002, 12:17 AM
