That's simple:
-Right click the .lnk file, click Properties.
-Where it says "Target" copy the text in it (say it's "C:\mytarget\mytarget.exe")
The targer is the "PATH" to the application you want to execute. You'll just have to edit/create any button in RR to execute the following command:
"RUNQ;C:\mytarget\mytarget.exe" -- using the text you got from your link.
To assign a button you'll basically have to find a button you don't use or an empty button and change the command on it to that command above. To use it in the launch screen, you'll have to follow this thread (where it talks about the launch screen): http://www.mp3car.com/vbulletin/rr-f...cation-rr.html
LinkBack URL
About LinkBacks
However, reading another post from Guino, this might work:
