Results 1 to 5 of 5
Thread: Playlist creation
    Jun 2003
    Memphis - TN
    Playlist creation
    I'm trying to create a button that will auto add music in a directory to a playlist.
    Heres what I have come up with.
    If I create a batch file (Hidden attribute) and use this
    Code:
    @echo off
    dir /o:n /b /A-H *.* > "C:\MUSIC\playlists\ALTROCK.m3u"
    It will create a playlist called ALTROCK.m3u
    Unfortunately it will not open with Winamp, just WMP.
    Winamp adds
    "#EXTM3U""
    "#EXTINF: ID TAG"
    "PATH\Filename"
    Without creating it manually with Winamp or using a 3rd party application, I cant seem to do this.
    Anyone know if this is possible?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The playlist without the #EXTM#U and #EXTINF lines should work fine in winamp as long as the lines have the FULL drive+path+filename -- I know this for a fact because RR itself will create this types of playlists for using with winamp. The file created by the command you posted will likely only have the FILENAMES (without drive or path) -- they should work as long as the playlist file is in the same folder with the files.
    You can create the playlists in RR or make some sort of script (or more complex command) to do what you're looking for .. for instance:
    Code:
    del /y ALTROCK.M3U
    for %f in (*.mp3) do echo %cd%\%f%>>C:\MUSIC\playlists\ALTROCK.M3U
    Ride Runner RR's Myspace
    Jun 2003
    Memphis - TN
    Quote Originally Posted by guino View Post
    Code:
    del /y ALTROCK.M3U
    Thanks Guino,
    Here's the code I used.
    Code:
    del /y C:\MUSIC\playlists\ALTROCK.m3u
    for %%f in (*) do echo %cd%\%%f>>C:\MUSIC\playlists\ALTROCK.m3u
    When I load up a list of songs in winamp, close RR, and it loads winamp, the previous songs are loaded still. What list is it loading? Do you know the location of this?
    I thought it was
    C:\Program Files\winamp\winamp.m3u
    This file doesnt seem to exist.
    Any clue?
    MySQL Error
    Oct 2004
    winamp NOW (if u using a new version since 5.3x) stores its data, AS IT SHOULD, in the USER PROFILE!!!
    in windows7/vista, winamp stores its data:
    C:\Users\mitchjs\AppData\Roaming\Winamp
    with your name in there
    i havent used xp in a long time, so its in some %appdata% dir
    now, when rr loads, we load rrpl.m3u8
    not by chance using DXF4?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Jun 2003
    Memphis - TN
    Naa, Im using my own version of BM skin. Thanks for the info! Now.. back to editing/testing.
  1. How About...A Virtual CD Changer
    By chuckster in forum Road Runner
    Last Post: 09-23-2011, 03:03 PM
  2. Playlist Strangeness
    By nasa in forum Road Runner
    Last Post: 08-17-2008, 10:05 AM
  3. load playlist on startup
    By Moneyfink in forum RR Bug Tracker
    Last Post: 12-04-2007, 07:08 PM
  4. Playlist creation
    By hari-bhari in forum Centrafuse
    Last Post: 12-12-2006, 02:30 PM
  5. batch file playlist creation size limit?
    By AndyM in forum Software & Software Development
    Last Post: 08-08-2001, 01:06 AM
