Results 1 to 10 of 17
Thread: Send a variable from autoit to rr
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I try to create a little autoit program who sen to RR a variable :
    Code:
    $rr.execute("SETVAR;Myvar;1800")
    With skin tool a see well that Myvar = 1800.
    In a skin , i want to see in a label code the varial resul , 1800.
    How can i write my ligne in my skin file please !
    Thanks for any help !
    May 2008
    Bordeaux, France
    Thanks Enforcer,
    And if i want that my label code is :
    Code:
    L,593,313,137,21,255,255,255,12,"Lucida Sans Unicode:B","TEST",
    What must to be my command in autoit do define my variable ?
    Code:
    $rr.execute("SETVAR;????????;1800")
    May 2008
    Bordeaux, France
    Quote Originally Posted by Enforcer View Post
    Code:
    Code:
    L,593,313,137,21,255,255,255,12,"Lucida Sans Unicode:B","=$myvar$",
    Yes Enforcer, I have tried your example and that's ok .
    But I should like to have in my skin that :
    Code:
    L,593,313,137,21,255,255,255,12,"Lucida Sans Unicode:B","myvar",
    What must to be my script command please ?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That is the correct way: L,.......,"Lucida Sans Unicode:B","=$myvar$",
    The only other way is to do: L,.......,"Lucida Sans Unicode:B","CUSTOMxxxxxx",
    You just put 'CUSTOM' in front of whatever you want to call your label.
    Then your scrip just uses the cmd: $rr.execute("SETLABEL;CUSTOMxxxxxx;Wazaaap!")
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can also do these variations:
    Code:
    L,593,313,137,21,255,255,255,12,"Lucida Sans Unicode:B","$myvar$",
    with command:
    $rr.execute("SETVAR;Myvar;=1800")
    OR
    Code:
    L,593,313,137,21,255,255,255,12,"Lucida Sans Unicode:B","!MyVar",
    with command:
    $rr.execute("SETLABEL;!Myvar;1800")
    (! is the same as "CUSTOM" -- but it may not work on all languages).
    You can NOT do this:
    Code:
    Because that is saying that the label should display a LABEL CODE called "myvar" which can only be an internal label code or a label code defined in an extension plugin.
    Ride Runner RR's Myspace
    May 2008
    Bordeaux, France
    Thanks Blue , thanks Guino.
    It's excately that i wanted to know !
    May 2008
    Bordeaux, France
    Smile
    Hi Guino,
    I try to create a new program who send two variables to RR;
    I have tried that:
    Code:
    $rr.execute("SETVAR;CUSTOM_GMAILMESSAGE;YOU HAVE SEVERAL MAIL !!!")
    $rr.execute("SETVAR;CUSTOM_GMAILNUMBER;"&$a)
    with this line on my skin file:
    Code:
    L,19,48,411,169,255,255,255,30,"Arail:B","CUSTOM_GMAILNUMBER","CENTER"
    L,11,8,427,25,0,0,0,20,"Arial:B","CUSTOM_GMAILMESSAGE","CENTER"
    and also
    Code:
    $rr.execute("SETVAR;!GMAILMESSAGE;YOU HAVE SEVERAL MAIL !!!")
    $rr.execute("SETVAR;!GMAILNUMBER;"&$a)
    Code:
    L,19,48,411,169,255,255,255,30,"Arail:B","!GMAILNUMBER","CENTER"
    L,11,8,427,25,0,0,0,20,"Arial:B","!GMAILMESSAGE","CENTER"
    Skintool see well my two variables but when i load my screen, nothing appear .
    I have tried these lines to finish:
    Code:
    $rr.execute("SETVAR;GMAILMESSAGE;=YOU HAVE SEVERAL MAIL !!!")
    $rr.execute("SETVAR;GMAILNUMBER;"=&$a)
    Code:
    L,19,48,411,169,255,255,255,30,"Arail:B","$GMAILNUMBER$","CENTER"
    L,11,8,427,25,0,0,0,20,"Arial:B","$GMAILMESSAGE$","CENTER"
    And it is ok for me .
    So the two first option don't run for me !
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    In autoit
    Code:
    $rr.execute("SETVAR;CUSTOM_GMAILMESSAGE;YOU HAVE NEW MAIL!")
    $rr.execute("SETVAR;GMAILNUMBER;" &$a)
    In your skin
    Code:
    L,19,48,411,169,255,255,255,30,"Arail:B","=$CUSTOM_GMAILMESSAGE$","CENTER"
    L,11,8,427,25,0,0,0,20,"Arial:B","=$GMAILNUMBER$","CENTER
  1. Lsx Void 3.0
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 12-11-2013, 04:05 AM
  2. RR Video Issue.....
    By grnLude in forum Road Runner
    Last Post: 05-20-2008, 01:24 PM
  3. feat req: RR path as system variable
    By liquid_smoke in forum Road Runner
    Last Post: 07-19-2006, 08:07 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
