Results 1 to 6 of 6
Thread: issue about HD RADIO and PRESET Station
    Constant Bitrate pijo1971's Avatar
    Nov 2004
    Novara - Italy
    hello,
    I would like to know why if I try to save a station with frequency like 102.5 MHz (by holding the number of preset position), the system cut the 0.5 Mhz and save only 102.0 MHz.
    So, when I change station and I return to the previusly position, the RADIO tune on 102.0 MHz and not on 102.5 MHz.
    What I wrong ?
    Also, is it possible to choose a different name ? The system by default use the frequency of the station (i.e. 102,5) but I would like to give a different name; is iti possible? How could I do?
    Cheers,
    luigi
    CarPC in Progress [||||||||-] 90%
    Visit my Project
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Are you using the latest RR version ? I remember there was a bug fis recently for HD radio involving a "," system issue. This could be your case, so you should verify you have the latest RR. If you don't want to update (we recommend updating), there's a high probability that setting your reginal settinngs (Control Panel) to US English should fix the issue.
    Ride Runner RR's Myspace
    Nov 2004
    Novara - Italy
    hello,
    my version (opening RideRunner Config) is
    Config version: 1.0.2.2
    RideRunner version: 12/02/09.
    b.t.w I've change the regional setting, and now is working.
    For the second question, is it possible change the label used to save the preset station? the label used automatically is the frequency of the station, but I would like to change this label.
    Thank you.
    Luigi
    Visit my Project
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by pijo1971 View Post
    You should be able to edit the label in Radio.INI, but some skins offer the function to edit the label in the radio screen itself -- the BMV2 skin has a menu with a MODIFY button that allows you to change the label of the radio station, other screens may have their own options.
    Nov 2004
    Novara - Italy
    Hi,
    now I'm using carwings skin.
    I have two Radio.ini file, one contain this instruction
    [Global]
    ComPort=3
    ExtApp=RoadRunner
    Minimized=1
    ScanLevel=80
    [Speicher]
    Ebene=1
    [SenderFRQ]
    0=103
    1=106,4
    2=99,4
    3=100,6
    4=100,6
    5=104
    [SenderName]
    0=
    1=
    2=
    3=
    4=
    5=
    [SenderPICode]
    0=0
    1=0
    2=0
    3=0
    4=0
    5=0
    and one contains only
    107
    Note: the five frequency in the first Radio.ini file are different than the real preset frequency that I have saved. It seems that there isn't a file that contain the 6 channels that I have saved.
    What do I have to do? I have to put below the [SenderFRQ] and [SenderName] the channels that I have saved?
    thanks,
    Luigi
    Visit my Project
    MySQL Error
    Oct 2004
    that top radio.ini IS NOT from standard RideRunner, no idea what thats from
    carwings skin, does not allow textual names... only FREQ #s
    and the ARE NOT saved in radio.ini, they are saved in skin.ini
    carwings is using simple presets, not a Preset List
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. HD Radio Commands
    By MGD in forum Road Runner
    Last Post: 07-23-2009, 04:01 PM
  2. Directed HD Radio Tuning
    By mattstevenson in forum Road Runner
    Last Post: 05-05-2009, 04:24 PM
  3. HD Radio Skin For BMV2
    By bratnetwork in forum RR Skins
    Last Post: 01-26-2009, 02:21 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
