what skin are you useing, it unsual to have a skin from here with no radio button,
I have Directed HD Radio dmhd1000 running on ride runner v 2/3/10. i am having an issue with getting the radio to work. there is no radio button on the skin. I have tried to configure it right. all the threads say it is an easy procces, but i can not see the radio button on the screen. Also I am a novice in program please help and thank you.
Miguel
Make sure it works with the MGS HD Radio PCR program first,
Then make sure you are using a skin that supports HD Radio
Then check back and tell us what you find out.
New Age Garmin - Skin for RR
I do not know what skin I am using but here is the screen pictures. Also can you explain " MGS HD Radio PCR program"
Thats DFX one of the most popular of skins , and it most defintly has a radio screen ,
if you don't see the radio button in the 2 menu screens , press & hold any button on any of the 2 menu screns , this will take you to a button selector screen from there you will find the radio button, select this and it will appear on the menu screen,
as for MGS PCR its a program to test Radio outside of Riderunner, you should be able to get this from Mitch's web site , look for a link in his signature .
why not keep things simple AT FIRST!!!
use the carwing_dyanmic_light supplied with riderunner
if hd radio is working in it, then its gonna work...
this assumes, you set up the radio to be HDRadio, with RRConfig, and its COMPORT
yes, download hdradio pcr, its a stand alone app...
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Thank you Guy's for all the help. I changed the skin to the elight and the hd-radio is working. Now I am having a problem with playing dvd’s and how to access the hd-2 radio stations.
if the skin is made for hd radio... im sure there is a button to go to next stream
i got elite lite, and there is
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
