Results 1 to 10 of 17
Thread: Audio problems with VLC on RR
    Sep 2007
    Italy
    Hi,
    I'm having some problems with RR and VLC. The videos are playing fine outside RR with VLC player, but for some videos played on RideRunner the sound is not clean. It's a lot higher than the video played outside RR, but not clear at all.
    I'm using the last version of RR (February'10), VLC 1.05. I have an epia nano itx NX 1500 with an external sound card Audigy 2 NX. I'm using the AUX ingression of my unit
    I prefer use VLC instead of Mplayer Classic which is crashing often, and it uses a lot of CPU in confront of VLC player.
    Can anyone please help me?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    RR uses the VLC component to play videos -- generally, whatever you setup in VLC outside RR is what will work inside RR. There's another VLC plugin you may want to try, but in RR we set the VLC plugin to play at 100% of the volume, if 100% volume is too high for your audio settings outside RR, then it will be too high inside RR as well. I would recommend trying to adjust the audio settings in VLC so that 100% volume plays fine outside RR then it will also play fine inside RR. If this can't be done, we may have to add a setting for the default volume to use inside RR when using VLC for video.
    Ride Runner RR's Myspace
    Sep 2007
    Italy
    Thanks Guino for answering to my question.
    I also set the volume to 100% outside RR but it's lower than the volume played inside RR. The volume is not a problem for me, the real problem is that the audio for some videos played indside RR are not clear, and the same videos played outside RR are clear.
    I also give a try to the other VLC plugin availble for RR.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    we're working on a default volume setting for the VLC video player for next release.
    Sep 2007
    Italy
    Thanks again guino, but maybe I did not explain well my problem, the louder volume is not a problem, the real problem is the audio quality.
    Playing a video inside RR with VLC has a lower audio quality than playing the same video outside RR with VLC.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This "lower quality" is likely just "distortion" of the audio caused from the higher volume. If the default volume setting doesn't fix it, I'm afraid you'll have to figure out what settings could be causing it on VLC itself (as the VLC control doesn't provide much of any audio control settings).
    Sep 2007
    Italy
    I could set up the lower volume on VLC and also lowered inside RR, but the audio quality inside RR it really sucks. I cannot use it in this way.
    I also uninstalled and installed the last version of RR but without positive results.
    What else could I do?
    MySQL Error
    Oct 2004
    you do relize, that RR does ZERO audio processing
    and i mean ZERO
    thats why it depends on other players, shuch as winamp, windows media play, vlc, media player classic... and on and on...
    something elses it at play with your set up...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Sep 2007
    Italy
    I know that the audio is processed by VLC and not RR, but outside RR every video plays fine, it's inside RR that I have problems. I don't know what should I do or what should I change to make it work.
    I also checked the CPU load and it's always under 50%. Nobody has similar problems?
    Aug 2004
    Germany
    @mitchjs:
    Just to get that right and narrow down the problem:
    You say that RR does nothing about audio. What about video ?
  1. Replies: 5
    Last Post: 08-23-2008, 08:38 PM
  2. Few problems Im having with RR,......Easy to fix if you know how?!
    By MrSkipsey in forum General MP3Car Discussion
    Last Post: 02-17-2008, 09:31 AM
  3. Can anyone help me with my RR problems?
    By mad212 in forum Road Runner
    Last Post: 01-28-2008, 02:39 PM
  4. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 08:40 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
