Results 11 to 20 of 30
Thread: Ride Runner and Windows 7 32bit
  1. #11
    Nov 2009
    I used the new version of rr that came out this month and gdi+ is checked. still same error. maybe i should just go back to xp and see if that works.
  2. #12
    Nov 2009
    bump for help/suggestions
  3. #13
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Post a zip of your rr.ini and your skin.ini (frm elite skin) so I can take a look at it.
    Ride Runner RR's Myspace
  4. #14
    Nov 2009
    ok at work right now will attach when i get home
  5. #15
    Nov 2009
    Attachment 58117
    Here is the two files I am using.
  6. #16
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I just wanted a zip file with your RR.INI and SKIN.INI -- those are just two small text files found in RR's folder and in the Elite skin folder. You posted a zip with RR and the Elite skin.
  7. #17
    MySQL Error
    Oct 2004
    ERROR: GDI+ support is requested, but unable to create object, possible cause, 'GDIPlusWrapper.dll' is not registerd
    this is why... did u strip anything out of the windows 7 installation you did?
    i have installed RR on many fresh windows 7, and NEVER had any issues
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #18
    Feb 2010
    I am having this same problem, fresh install of windows 7 (from an iso) as well as fresh installs of riderunner, flash, directx, everything else i could think of. Im thinking since its a fresh OS i may need to update video drivers, as this may be causing issue (correct me if im way off) but here are my rr and skin ini files.
    Attached Files Attached Files
  9. #19
    Nov 2009
    ok i got mine fixed by installing gdi+ from microsoft and reinstalling ride runner. Now I have a new issue. Everything works with ride runner except my music player. I can play music from my music folder on my desktop. When I try to play music using ride runner it shows the song to be playing but I have no sound. Go out of ride runner and play music straight from the folder its saved in and everything works fine. So, just no sound when playing music from ride runner. Any ideas?
  10. #20
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by J_Eatwell View Post
    Your INI files seem fine.. there must be something in common between your install and Josh's that is causing the issue. I also have Win7 32bit (Ultimate) setup on a laptop and it has no issues. Could be something related to the install or OS related. You may want to try looking for this GDI+ for win7 (which should already be in there though), then re-install -- maybe a win7 starter doesn't come with it or something ?
  1. 07 Chrysler 300 Limited - In Dash PC
    By BCasey in forum Worklogs
    Last Post: 07-24-2012, 09:27 AM
  2. Road Runner on Windows 7 beta
    By DaveDog in forum Road Runner
    Last Post: 12-18-2009, 12:02 PM
  3. starting road runner with windows
    By taker73044 in forum Road Runner
    Last Post: 09-22-2008, 11:22 AM
  4. Windows media player in Road Runner?
    By bigbuffs in forum Road Runner
    Last Post: 01-02-2008, 11:01 PM
  5. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 01:58 PM
