Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Ride Runner and Windows 7 32bit
    Nov 2009
    OK i just installed a new board (intel d510mo) with 2gb ram and a 250gb sata drive. My old board crashed. So, I after installing windows and all updates, I installed ride runner and it doesn't work. I used the config screen and changed everything like I had it on the old computer running xp. I go and open ride runner and get the following message:
    Ride Runner Car Entertainment Center has stopped working
    Windows can check online for a solution to the problem.
    Check online for a solution and close the program
    Close the program
    Debug the program
    I have done all three and everytime I start riderunner i get this message. I have tried the default skin and elite lite neither one gets me past this point. I know people are using windows 7. How do I fix this?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    can u make a debug log ? since you're using windows 7 - did you install .NET for the audio mixer support ?
    Ride Runner RR's Myspace
    Nov 2009
    i don't know how to make the debug log and i just installed the new ride runner release thats it.
    Nov 2009
    2/17/2010 9:11:53 PM: Start -- Version: 2/1/2010
    2/17/2010 9:11:53 PM: OS Type: Windows 7
    2/17/2010 9:11:53 PM: FileManager: FileMode = Legacy
    2/17/2010 9:11:53 PM: FileManager: mypath = C:\Program Files\RideRunner\
    2/17/2010 9:11:53 PM: FileManager: ProfilePath = C:\Users\CarPC\Documents\RideRunner\
    2/17/2010 9:11:54 PM: VMC---> Set object successful
    2/17/2010 9:11:54 PM: VMC---> SOURCE: Playback Input line #1: "Speakers"
    2/17/2010 9:11:55 PM: PLAYER: Winamp Version:
    2/17/2010 9:11:55 PM: DirectDraw Count: 1 - []
    2/17/2010 9:11:55 PM: No Phidgets interface detected.
    2/17/2010 9:11:55 PM: Plugin Manager: loading Global Plugins...
    2/17/2010 9:11:55 PM: Plugin Manager: Plugin Found: SkinTool
    2/17/2010 9:11:55 PM: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
    2/17/2010 9:11:55 PM: Plugin Manager: Plugin loaded (Global): SkinTool
    2/17/2010 9:11:55 PM: Plugin Manager: Plugin Found: Weather
    2/17/2010 9:11:55 PM: Plugin Manager: Plugin loaded (Global): Weather
    2/17/2010 9:11:55 PM: Plugin Manager: loading Global Plugins Completed.
    2/17/2010 9:11:55 PM: LoadSkin: C:\Program Files\RideRunner\Skins\Carwings_Dynamic_Lite\
    2/17/2010 9:11:55 PM: Plugin Manager: loading SkinDir Plugins...
    2/17/2010 9:11:55 PM: Plugin Manager: loading SkinDir Plugins Completed.
    2/17/2010 9:11:55 PM: ERROR: Loading image file(s) for: menu.skin (Failed to load control
    Nov 2009
    2/17/2010 9:21:24 PM: Start -- Version: 2/1/2010
    2/17/2010 9:21:24 PM: OS Type: Windows 7
    2/17/2010 9:21:24 PM: FileManager: FileMode = Legacy
    2/17/2010 9:21:24 PM: FileManager: mypath = C:\Program Files\RideRunner\
    2/17/2010 9:21:24 PM: FileManager: ProfilePath = C:\Users\CarPC\Documents\RideRunner\
    2/17/2010 9:21:24 PM: VMC---> Set object successful
    2/17/2010 9:21:24 PM: VMC---> SOURCE: Playback Input line #1: "Speakers"
    2/17/2010 9:21:25 PM: PLAYER: Winamp Version:
    2/17/2010 9:21:25 PM: DirectDraw Count: 1 - []
    2/17/2010 9:21:25 PM: No Phidgets interface detected.
    2/17/2010 9:21:25 PM: Plugin Manager: loading Global Plugins...
    2/17/2010 9:21:25 PM: Plugin Manager: Plugin Found: SkinTool
    2/17/2010 9:21:25 PM: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
    2/17/2010 9:21:25 PM: Plugin Manager: Plugin loaded (Global): SkinTool
    2/17/2010 9:21:25 PM: Plugin Manager: Plugin Found: Weather
    2/17/2010 9:21:25 PM: Plugin Manager: Plugin loaded (Global): Weather
    2/17/2010 9:21:25 PM: Plugin Manager: loading Global Plugins Completed.
    2/17/2010 9:21:25 PM: LoadSkin: C:\Program Files\RideRunner\Skins\eLite Lite\
    2/17/2010 9:21:25 PM: Plugin Manager: loading SkinDir Plugins...
    2/17/2010 9:21:25 PM: Plugin Manager: loading SkinDir Plugins Completed.
    2/17/2010 9:21:26 PM: ERROR: Loading image file(s) for: menu.skin (Failed to load control 'Flash' from . Your version of may be outdated. Make sure you are using the version of the control that was provided with your application.)
    Since this one isn't working on this computer I tried to install it on my laptop using windows 7 64bit and everything works fine. Used all the same files I used to install on this computer
    guino's Avatar
    Nov 2004
    Toronto, Canada
    as you can see from this line:
    It is complaining that you do not have the latest version of Flash installed. Try updating and see if it helps.
    Nov 2009
    will do - thanks
    MySQL Error
    Oct 2004
    flash installer is on a sticky in this forum
    http://www.mp3car.com/vbulletin/road...sh-10-now.html
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Nov 2009
    now I get this:
    2/18/2010 7:47:53 PM: Start -- Version: 2/1/2010
    2/18/2010 7:47:53 PM: OS Type: Windows 7
    2/18/2010 7:47:53 PM: FileManager: FileMode = Legacy
    2/18/2010 7:47:53 PM: FileManager: mypath = C:\Program Files\RideRunner\
    2/18/2010 7:47:53 PM: FileManager: ProfilePath = C:\Users\XRunner\Documents\RideRunner\
    2/18/2010 7:47:53 PM: ERROR: GDI+ support is requested, but unable to create object, possible cause, 'GDIPlusWrapper.dll' is not registerd
    2/18/2010 7:47:54 PM: VMC---> Set object successful
    2/18/2010 7:47:54 PM: VMC---> SOURCE: Playback Input line #1: "Line In"
    2/18/2010 7:47:54 PM: VMC---> SOURCE: Playback Input line #2: "Microphone"
    2/18/2010 7:47:55 PM: DirectDraw Count: 1 - []
    2/18/2010 7:47:55 PM: No Phidgets interface detected.
    2/18/2010 7:47:55 PM: Plugin Manager: loading Global Plugins...
    2/18/2010 7:47:55 PM: Plugin Manager: Plugin Found: SkinTool
    2/18/2010 7:47:55 PM: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
    2/18/2010 7:47:55 PM: Plugin Manager: Plugin loaded (Global): SkinTool
    2/18/2010 7:47:55 PM: Plugin Manager: Plugin Found: Weather
    2/18/2010 7:47:55 PM: Plugin Manager: Plugin loaded (Global): Weather
    2/18/2010 7:47:55 PM: Plugin Manager: loading Global Plugins Completed.
    2/18/2010 7:47:55 PM: LoadSkin: C:\Program Files\RideRunner\Skins\eLite Lite\
    2/18/2010 7:47:55 PM: Plugin Manager: loading SkinDir Plugins...
    2/18/2010 7:47:55 PM: Plugin Manager: loading SkinDir Plugins Completed.
    2/18/2010 7:47:55 PM: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (main.png)
    2/18/2010 7:47:55 PM: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (menus.png)
    2/18/2010 7:47:55 PM: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (on.png)
    2/18/2010 7:47:55 PM: ERROR: Loading image file(s) for: menu.skin (Invalid picture)
    2/18/2010 7:48:05 PM: Shutdown: (1)
    2/18/2010 7:48:05 PM: Shutdown: (2)
    2/18/2010 7:48:05 PM: Shutdown: (3)
    2/18/2010 7:48:05 PM: Shutdown: (4)
    2/18/2010 7:48:05 PM: Plugin Manager: ALL Plugins unloaded.
    2/18/2010 7:48:06 PM: Shutdown: (5)
    2/18/2010 7:48:06 PM: Shutdown: (6)
    2/18/2010 7:48:06 PM: Shutdown: (7)
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you used the installer then you should have everything you need... you probably just need to open RRConfig, go into General->Page 2 and make sure that "screen fast mode" is selected to "GDI+".
  1. 07 Chrysler 300 Limited - In Dash PC
    By BCasey in forum Worklogs
    Last Post: 07-24-2012, 10:27 AM
  2. Road Runner on Windows 7 beta
    By DaveDog in forum Road Runner
    Last Post: 12-18-2009, 01:02 PM
  3. starting road runner with windows
    By taker73044 in forum Road Runner
    Last Post: 09-22-2008, 12:22 PM
  4. Windows media player in Road Runner?
    By bigbuffs in forum Road Runner
    Last Post: 01-03-2008, 12:01 AM
  5. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 02:58 PM
