Results 1 to 3 of 3
Thread: RR master volume not working
    Jun 2006
    Heya all,
    I search the forum, and dit try all things they sad but noting helps me whit the problem I have.
    I dit new update for RR and after the update I can not control my Volume + and - any more and the % wont go up ore down, when I use my powermate volume gos up but % stays at 0%, mute works, I testet other skins, all the same problem, when I set RR config to wave, all lines ore other then master volume all works fine, only master wont go up.
    I reinstalled drivers, RR and Winamp few times but problem keeps same, I dit new install on other Pc and all works like a charm.
    Before the update everything was working fine, don't know what the problem is, sound card works good, dit no new update to it ore dit not make any changes and powermate makes the Windows Volume slide bar go up and down, and sound works ok then.
    Hope you understand what I am saying (English not main language)
    Thx already
    MySQL Error
    Oct 2004
    how about, OS version...
    better yet, a debug.txt attached of a session
    for sure all lines isnt a good choice, not for modern audio systems
    the update rate of the volume when your power mate, will be late on the rr
    but if rr isnt controlling the volume, then you wont get any upadate
    mastervolmap=0
    is where i would put it
    attach a debug.txt, that will answer most of our questions
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Jun 2006
    Here is my Debug.
    I think I am having same problem as this person http://www.mp3car.com/vbulletin/road...-7-1-hifi.html
    Attached Files Attached Files
  1. Volume control and ASIO sound card in RR
    By rodweb in forum Road Runner
    Last Post: 08-07-2009, 02:43 PM
  2. volume control shortcut in RR
    By bigbuffs in forum Road Runner
    Last Post: 07-28-2008, 03:04 PM
  3. Volume Issue after opening RR
    By bmzero in forum Road Runner
    Last Post: 06-20-2007, 09:28 AM
  4. Set Volume control to winamp instead of master
    By Ne-o in forum Road Runner
    Last Post: 01-01-2006, 06:20 PM
  5. Map Master Volume to WINAMP VOL ?
    By liquid_smoke in forum Road Runner
    Last Post: 08-07-2005, 02:06 AM
