Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 49
Thread: Record and/or Memo Sirius
  1. #31
    Jul 2009
    B.C., Canada
    Bahahaha. I'm delirious.
    I'm so close I'm calling it close enough. Here's what it does now.
    I'm in Sirius, I hit MP3 and it lists my MP3s in a DL while still playing Sirius. When I go into a folder if there are any MP3s in that folder Sirius stops and nothing plays, then when I click on an MP3, it starts to play. If there are no MP3s in that folder Sirius keeps playing.
    Not ideal but close.
  2. #32
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    u want it to keep playing while you're choosing the song ? or you want it to stop regardless ? what's the .skin file for your MP3 listing screen ?
    Ride Runner RR's Myspace
  3. #33
    Jul 2009
    B.C., Canada
    I want to be able to look at all my MP3s without Sirius stopping, then when I select a song, I want Sirius to stop and the MP3 to play.
    The skin I'm using for my MP3 DL is simply mp3.skin because if I use audio_browser it will automatically change the input source to audio as soon as I go to it, stopping Sirius right away.
  4. #34
    Jul 2009
    B.C., Canada
    Did you have any ideas on that one Guino? I'm stumped on making this work the way I want it to.
  5. #35
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You should be able to use "LOAD;MP3.skin" with a Dir list in it to view your mp3 songs without stopping SIRIUS. On your "SELECT" button, you should use "SETSOURCE;AUDIO||SELECT||AUDIO" or something of that effect -- to switch to mp3 (stopping sirius), then select the song, and going to the audio player.
  6. #36
    Jul 2009
    B.C., Canada
    Man, really?!
    I did all of that but put "AUDIO" at the end. I didn't think I had to switch to the audio_player skin to play since it technically can play from any skin. I also didn't try a "SELECT" button, I tried putting it in the ExecTBL with various commands so that it would happen as soon as I clicked the MP3 saving myself a button push but even with "AUDIO" in there it doesn't switch and plays both at once. That's ok though, I can do it this way too. It seems odd I'd have to set the source to AUDIO AND switch to the AUDIO skin (which switches the source automatically so I tested it without SETSOURCE and it does work, just not quite as well. It plays the MP3 before turning off SIRIUS for about 1 second.
    Regardless, this does what I want it to do closer than anything I came up with.
    THANKS AGAIN GUINO!
  7. #37
    Jul 2009
    B.C., Canada
    I found two problems that I'm working on now, but thought I'd post anyways incase someone has an idea.
    1) If I'm switching from SIRIUS to MP3 unless I put "PLAY" in the SELECT button("SETSOURCE;AUDIO||SELECT||AUDIO||PLAY"), Winamp selects the song but it's stopped. If I already am playing an MP3 but want to select a different one it does play without needing "PLAY" in the button command, meaning if I leave it in, it Pauses.
    2) If I'm going from one MP3 to another I can only use the SELECT button if I'm choosing an MP3 in a different folder. If it's the same folder it replays the first song.
  8. #38
    Jul 2009
    B.C., Canada
    Problem number 2 is fixed and I feel that number 1 is unfixable, easily anyways. Now I can get back to the origional topic of this thread and work on a memo feature.
  9. #39
    Jul 2009
    B.C., Canada
    Is it possible to use SRINFO as a single variable/is it already, like turn "SRINFO;40;%artist% - %title%" into $SIRIUS40$?
    I tried using SETVARBYCODE but that didn't seem to work, maybe because of all the semicolons? I have "SETVARBYCODE;mp3label1;TAGARTIST" used for a different reason and works fine.
  10. #40
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If this is the currently tuned station you can use setvarby code with the trackname label code -- or the TAGXXX codes. The semi-colons do cause an issue for setvarbycode, because it assumes the parameters after the ; are for formatting the labelcode. I can definitely look into a suitable solution if you provide a little detail on what you're trying to accomplish with that info on a variable.
  1. XM / Sirius Worklog
    By Nola111 in forum Centrafuse
    Last Post: 08-20-2008, 11:05 AM
  2. sirius and hibernation
    By bay350z in forum Road Runner
    Last Post: 06-10-2008, 03:11 PM
  3. Sirius and MJS
    By randomjohn in forum Road Runner
    Last Post: 03-08-2006, 11:42 AM
  4. Sirius PCR ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 03-15-2005, 05:55 PM
