Results 1 to 5 of 5
Thread: RRFusion:- threshold, Alerts and Indicators
    Oct 2008
    Wiltshire, UK
    I am using a Fusion Brain V4 and RRfusion with ride runner. So far it's all going well and I am skinning all the required gauges and inputs. I have however hit one problem,
    I am triggering an indicator to appear once one the inputs goes high. This should then disappear once the input goes low again.
    By using the threshold and ALERT function of RRfusion I can get the indictor to appear correctly using the following entries:-
    ExecTBL.ini
    "RRFUSION_ALERT3","SETIND;!LEFT_INDICATOR;ON"
    "RRFUSION_ALERT4","SETIND;!RIGHT_INDICATOR;ON"
    and
    rrfusion_threshold.ini
    Analog0 = Raw;999;>;Port 0 over limit
    Analog1 = Raw;999;>;Port 1 over limit
    Analog2 = Raw;999;>;Port 2 over limit
    Analog3 = Raw;70;>;Indicate Left
    Analog4 = Raw;70;>;Indicate Right
    What I can't do is clear the indicator once it's been set? From what I can see you can set up a trigger on over voltage but not under voltage?
    I could use the timer function of RideRunner to clear the variables periodically but I'm using the timer function for other applications.
    Am I missing something?
    Cheers, Trevor.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I am working on the code to make use of an over/under function. I've done the same with the centrafuse plugin i created and it appears to work better. No ETA but it should happen rather soon.
    Live mp3Car Facebook Chat
    Raw Wave
    Nov 2009
    What are you using as a trigger when it goes low?
    IE - goes hi = trigger on. goes lo = trigger off.
    Oct 2008
    Wiltshire, UK
    Quote Originally Posted by Sonicxtacy02 View Post
    Cool, fantastic. I thought I may have been missing something!
    Woodbridge, VA
    Blog Entries
    55
    basically if it exceeds the threshold (greater than OR less than) the alert event is run. Once it returns to its normal state (outside of the alert range) the off event is run. Both events run once only.
