Results 1 to 5 of 5
Thread: another riderunner sound issue
    Nov 2009
    Ok, I broke off the end of a 3.5mm connection in my motherboards line input port. I managed to get it out but now the port doesn't work. So I am going to have to use a pci sound card (i guess there is no other way) to connect my hd radio to my board to get sound. I am using windows 7. I can not get ride runner and the elite lite skin to turn on sound via the pci sound card input port. I can go to my system sound setting and open that connection and i have sound. so i know the hd radio and sound card are working. However when I click the hd radio button on my skin i get no sound. So, I guess it is not enabling the right line input port. Does this make sense? If so, how can i find out the correct path to the pci sound card port. I think in rr config I can choose the port to use but I have no way of knowing what to use there. thanks for the help.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Easiest way would be to disable your onboard sound card. Otherwise you have to set the soundcard (mixer) you want RR to manage so it can mute/unmute and control the volume of the right lines. You could probably just use a CD/AUX input of the motherboard which is a plug directly on the board (not needing an extra card at all).
    Ride Runner RR's Myspace
    Nov 2009
    how do i make rr use two different sound cards. With windows xp i could disable the internal sound card but with windows 7 i am having issues. I chose the pci sound card as my default line to use for input but this didn't work. i am using the Intel BOXD510MO Intel Atom D510 Intel NM10 Mini ITX Motherboard
    guino's Avatar
    Nov 2004
    Toronto, Canada
    In RR you should look at the soundcard= setting (should also be in RRConfig). RR can only control ONE sound card at a time.
    MySQL Error
    Oct 2004
    you have to capture!!!! capture sound on sound card x, play to sound card y
    use winamp line in plugin
    id consider this advanced...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. New Chip Provides High-End Sound
    By DarquePervert in forum Car Audio
    Last Post: 12-06-2006, 10:58 AM
  2. pyle pltvdin65 sound issue
    By bigsixx in forum Car Audio
    Last Post: 11-13-2006, 09:50 AM
  3. sound card help...
    By pimpmode in forum General Hardware Discussion
    Last Post: 06-01-2005, 11:32 PM
  4. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 10:04 AM
  5. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 09:01 AM
