Results 1 to 5 of 5
Thread: RR, Winamp, USB Audio Problem
    May 2007
    I just switched to a USB audio solution for my sound, it's an older Creative Labs model, picture here: http://i1.lelong.com.my/UserImages/I...[email protected]
    Winamp works great when RR isn't running, but when I load RR, Winamp gives me errors saying it's unable to write or create the DirectSound buffer, etc. When I go into the output plugin settings for Winamp it says "Device in use (?)" which seems to be the case. I'm not getting any sound from RR either though, the Silabs USB radio doesn't send anything though the USB card either, though thats a lesser concern for me.
    It seems like both RR and Winamp are trying to use the same audio device at the same time and apparently that's not working.
    Any advice on this?
    /edit I think it's a Sound Blaster Connect SB02070.
    MySQL Error
    Oct 2004
    RR doesnt manage ANY audio... all RR's audio is done by third party software... ie winamp
    ... wmp....foobar
    now the silabs, dll, manage its own audio... if not using the winamp line in plugin...
    but since you provided no info about OS and rr ver and such... cant tell you anymore info
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2007
    Quote Originally Posted by mitchjs View Post
    ... wmp....foobar
    Sorry, WinXP, latest RR build.
    But you just said something that I just figured out. I selected the option to use the line-in for the Radio, now everything else but that works. I think I need to configure the options for that though. Music and GPS are good for now.
    MySQL Error
    Oct 2004
    if you use the LINE-IN Plugin, you of course have to have that installed and configured correctly to even use it
    i use it.. i make a preset called silabs
    and the line in param is simple then
    lineinpar=line://preset=Silabs,title=Radio
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2006
    Quote Originally Posted by nitefallz View Post
    Try Windows 7 Home, external USB device issue will be solved by the OS.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Replies: 0
    Last Post: 02-11-2010, 01:10 PM
  3. Winamp not loading when i start RR
    By jr4284 in forum RR Bug Tracker
    Last Post: 12-21-2009, 09:15 AM
  4. Replies: 11
    Last Post: 09-06-2009, 09:20 AM
  5. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
