Results 1 to 7 of 7
Thread: Winamp not staring with RR
    Feb 2006
    RR version 3/2/10
    Winamp V5.13
    I just went through a complete reinstall from operating system on up. I use RR and DFX 4.0. I remember this happening every time I start from scratch but I can't remember the resolution. When I start RR winamp does not start with it. If I look at the task list winampa.exe is running before and after but winamp never starts. Config is set to winamp (auto) and winamp is installed in default location V5.13.
    Also, posibly related, I cannot get the skin to accept a "Select" command. I hit the button but the playlist never loads any songs. This is true even if I manually load Winamp before or after RR has loaded. Winamp and RR are not speaking to eachother.
    Any ideas on how to solve/debug?
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Try that manual option for winamp... I had an issue with it once and I did it manual and it worked for me.
    MySQL Error
    Oct 2004
    whats "winampa.exe"
    also v5.13 is very old, doesnt support unicode, just a FYI
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    winampa is the winamp agent.. it's a silly taskbar icon. Update to the latest winamp and run RRconfig to set the winamp to manual like suggested above, and set the path to it.
    If that still doesn't work, it could be something wrong with your install (or maybe you did not use the installer?) -- if this is the case you'd have to register the winamp player in the RR folder before using it (regsvr32 winamp.dll)
    Ride Runner RR's Myspace
    Feb 2006
    I did use the installer but now that you say that I remember that registering the dll is what fixes it. I did that and all is well.
    Q. I thought Winamp 5.13 was the desired version to use with RR. Is that no longer the case?
    MySQL Error
    Oct 2004
    for sure not, if you are dealing with Unicode
    not to mention the security bugs in a old version like that
    update to the newest it works find with rr..and is UAC compliant
    that true way back in RoadRunner days, when the winamp module didn't know about
    winamps placement of the settings file... but not anymore
    i use the latest winamp...
    and as guino said, install RideRunner with the latest installer
    (which would register all needed dlls, there should not be a need to manually register)
    and install winamp with its installer
    and if you do, auto should work
    debug.txt will also tell you info
    if you see...
    3/27/2010 8:52:08 PM: PLAYER: Winamp Version: 5.57
    then RR, successfully found and started winamp
    (if ur hiding the player, if not, you will know anyway )
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by EricE View Post
    A few versions after 5.13 were very unstable, so we were suggesting 5.13 for awhile (until new stable versions came out). These days the latest versions should be very stable and work best with unicode. If you don't need unicode, then 2.95 should still be ok.
  1. Replies: 11
    Last Post: 09-06-2009, 09:20 AM
  2. Update RR with changes from Winamp
    By drewbp in forum Road Runner
    Last Post: 05-22-2009, 02:29 PM
  3. Three questions regarding RR, winamp, gps
    By Profozone in forum Road Runner
    Last Post: 02-18-2008, 08:53 AM
  4. Problem with WINAMP in RR - Needs help!
    By Visions in forum RR Bug Tracker
    Last Post: 08-18-2007, 01:03 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
