Page 12 of 12 FirstFirst ... 23456789101112
Results 111 to 120 of 120
Thread: RR 04-01-2010 Release
  1. #111
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, he/we are talking about the KillWinamp cmd that is in the DFX 4 skin.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #112
    MySQL Error
    Oct 2004
    mhra no 2, please use the supplied carwings skin as the skin to test with
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #113
    Low Bitrate nhra no 2's Avatar
    Aug 2006
    Aurora, IL
    Yes it probably is a problem with DXF4. When I run RR using Carwings, the RRPL file info changes/or updates during open and close (ie. playlists work correctly). What is causing this problem in DXF4?
  4. #114
  5. #115
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I'm starting to think that created more of a problem than it was suppose to fix...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #116
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    And just what was it supposed to fix?
  7. #117
    MySQL Error
    Oct 2004
    someone clean out that, and post the corrected files
    prob enough to remove something in exectbl.ini
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #118
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Enforcer View Post
    It was supposed to fix WA not closing sometimes when RR was closed and upon RR starting up, caused it to hang b/c WA was also hung with not closing
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #119
    Aug 2006
    Aurora, IL
    Yes, I searched and found out how to remove kill WA from the exit_skin. Once I did this, RR would close and keep my playlist as I left it. Only WA still keeps playing if I just exit out of RR. I am OK with that for now, as most of the time I put it into hibernate. But I think there is another item somewhere else in DXF4 causing this. As I said before I am building a new carputer, my current setup will not play nice with audio & on board video ( a system conflict not listed, and can't find it). And on my current carputer, it has the kill WA in the exit_skin. When I exit RR, and then restart RR my playlist is as I left it. Also WA is shut down correctly.
    Can I copy the DXF4 directory from my old carputer, and paste it into my new carputer? This could possibly bring in all the config files, to see if some setting somewhere might shut WA down as it should.
  10. #120
    MySQL Error
    Oct 2004
    there is an option to KEEP WINAMP open after exiting RR, make sure you dont have that on
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. XM Direct protocol, Need help with commands !!!
    By Cinfraco in forum Car Audio
    Last Post: 07-28-2007, 05:10 AM
  2. RR + Mappoint 04 Not workin?
    By IntellaWorks in forum Road Runner
    Last Post: 07-13-2006, 10:19 AM
  3. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 07:48 PM
  4. RR 05-28-05.. Early Release..
    By guino in forum Road Runner
    Last Post: 06-04-2005, 08:36 PM
  5. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 12:27 PM
