Great work, is there a link to the plabs radio?
Cheers dude.
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
The epitome of Function over form and is probably the best Car PC in Europe.
Visit my Homepage
its a russian silabs clone, even google cant find it
http://www.digitalcar.ru/shop/produc...oducts_id=3065
FM only, uses same chip as all other sliabs based ones
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
not sure why you're posting your debug, you for sure are skilled enough to review
nor i dont know what we are looking for
ONLINE
MENU;MessageBox.skin
ONSCREENCHANGE
SETVAR;INFOTITLE;NewMessage !!!
SETVAR;MESSAGE;YOU ARE ONLINE !!!
ONSOURCECHANGE
ONSONGSTART
note, that the initial online, is coming before ONSKINSTART
so it might not show that, but if u simulated a offline, and a following online
i dont know
there is basiclly nothing in your log with offline, to online...
so i would suggest you to some more tests
you dont need me
i bet if you USE SKINTOOL...
INFOTITLE & MESSAGE vars are set
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
That i try is to see how these new events online and offline work.
And, if i understand well i can to add any command after the "ONLINE" and the "OFFLINE", or this is an error ?
My msgbox is just a test, but i think that is it possible to run any command RR or exe, yes ?
If i use this line:
i don't see my label menu.Code:"ONLINE","MENU;MessageBox.skin||SETVAR;INFOTITLE;NewMessage !!!||SETVAR;MESSAGE;YOU ARE ONLINE !!!"
but if i use this line:
i see well my labels menuCode:"ONLINE","run;notepad.exe"
I have tried to put my two line after the onskinstart command and i have the same issue.![]()
like i said, the ONLINE Event is firing before ONSKINSTART
so i dont think u will see it...
yes, any command...
does notepad open?
has nothing to do with where it is in the exectbl (not exactly)
after rr is running...
try, disconnecting internet, and u will see OFFLINE fire, then reconnect internet, and u will see ONLINE fire
ps these are NOT new events...been in RR for some time, but fixed they used to fire missing 1st and last letter
ALSO TO NOTE, the "ONLINE" indicator must be on the skin... ill fix this... but for today.. if you want the online/offline events, the indicator must be present
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Mitch you & I have been down this road beforeit was a bug with the was radio setting you fixed it for 3-02 release on your ftp.
my memory is not remembering a sirius radio setting issue
but you say i fixed it![]()
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
