Page 6 of 12 FirstFirst 123456789101112 LastLast
Results 51 to 60 of 120
Thread: RR 04-01-2010 Release
  1. #51
    MySQL Error
    Oct 2004
    ouch, killing RR isnt a good idea anyway
    RR got things to do when i gets the hibernation signal, like ask winamp to give me current playlist position, and save it to resume.ini
    no changes to RR shutdown behavior changed from 3-1 to 4-1 build
    (out side of a skin name path)
    but for sure there is NO way you should Kill RR, close it properally... which CloseRR does i guess...
    why are you closing it anyway? can i ask that, why not keep it open...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #52
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    My system just seems to work better with it closing RR and restarting on resume. I also like to leave the PC on for 10 minutes, for when I run into 7-11 or the gas station etc, so I dont have to wait for a restart, but have the music resume exactly where I turned the car off. Trying to emulate as much as possible an auto install environment.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  3. #53
    Maximum Bitrate Dalailama's Avatar
    Jan 2006
    Novara Italy
    Hi dudes,
    There is a problem with the new release of RR.
    Some users reported me a bug reveled by my skin (CrystalSilver).
    I tested myself and it is true!
    When RR starts some images aren't shown untill mouse pointer passes over them.. then they appear!
    It happens when images are loaded into screen with the code like:
    INC,titlebutton0.txt
    IMG,27,107,169,55,#TITLEBUTTON0#,EMPTY
    where titlebutton0.txt contains:
    /DEFINE TITLEBUTTON0 "music_title.png"
    It works well with RR Aug.2009 version and before.
    It is possible to fix the bug?
    Thanks.
    Live today like it is your last day, and behave as though you will live forever...
    my WEBSITE
    MapMonkey Dalai skin-preview-download ITA-email me for ENG
    Road Runner CrystalBlue skin-preview-beta release
  4. #54
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Dalailama View Post
    Hi dudes,
    Thanks.
    This was an improvement made to prevent useless drawing of buttons when the empty and off layers are the same image. I'm still thinking if it's a good idea to do something to fix this. There are currently 2 ways to fix this:
    Method 1:
    -Make a copy of your empty image and save it as off and adjust the 3rd line so that the empty and off layers don't use the same image.
    Method 2:
    -Add a OUT line for each EMPTY IMG definition (just copying the original one) so you'd have pairs like this:
    IMG,27,107,169,55,#TITLEBUTTON0#,OUT
    Method 2 is recommended for performance reasons as it tells RR to draw only what's necessary. Method 1 will work fine but will basically skip the performance improvements made.
    Ride Runner RR's Myspace
  5. #55
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    OK Guys can some 1 pls confirm if the weather is still working or is it dead now again with the latest ver of RR and Dfx 4.0
    Atleast am not able to update it anymore...
    Thanx
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  6. #56
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Yes.. just tried the weather.. it is working fine and we haven't changed anything on it for a few versions now.
  7. #57
    Dec 2003
    can u pls help me with weather skin...
    am not able to get it working...where can i start it from
    Was able to update it till 16th Jan..2010
    Thats what it shows even now..Same date and same data
    thanks
    vicky
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
  8. #58
    MySQL Error
    Oct 2004
    Quote Originally Posted by vicky_obee View Post
    thanks
    vicky
    try it in carwings...
    click more on 1st menu screen
    then weather
    must have access to internet connection
    also.. setup weather settings
    in RRCONFIG
    or edit rr.ini
    like
    [Weather]
    cityweather=Lansdale,PA
    weatherunits=USA
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #59
    Nov 2004
    St Louis
    Quote Originally Posted by guino View Post
    I am so jealous of your weather - 80 degree days and 70 degree nights. Must be nice.
  10. #60
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    thanks
    vicky
    Go to weather.com and check the settings for your area.
    I know they changed the abbreviations and format of my local area a few months ago.
  1. XM Direct protocol, Need help with commands !!!
    By Cinfraco in forum Car Audio
    Last Post: 07-28-2007, 06:10 AM
  2. RR + Mappoint 04 Not workin?
    By IntellaWorks in forum Road Runner
    Last Post: 07-13-2006, 11:19 AM
  3. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 08:48 PM
  4. RR 05-28-05.. Early Release..
    By guino in forum Road Runner
    Last Post: 06-04-2005, 09:36 PM
  5. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 01:27 PM
