April Fools edition... heck I thought about saying we're going back to Road Runner... But you know...
anyway...
We got a new release for you of course, packed with new features(not really) and some bug fixes(yes really)
Download from here
Some Highlights:
- DAB Venice5 Radio Module
- PLabs Digital Car Radio FM Radio Module
Thanks to Guino
Thanks to Bluezx3!
Thanks to Fixerofallthings (for carwings skin help)
Thanks to Griff1, nrgizerbunny, and Andy W for all their DAB Radio Work
Thanks to the people who test and report issues (we fix em as fast as we can, usually instantly)
Code:
LEGEND:
- = Removed
+ = Added
* = Changed
! = Major code change
# = Bug fix
^ = Note
03/31/10
+ Skin Command: "SETPATH" lock option, ex: "SETPATH;c:\mynewpath;lock" (locks user into this path, back will not "go up")
+ Skin Command: "HOME" same as "!BROWSE" (used to return to MUSIC_PATH or VIDEO_PATH depending where at)
03/30/10
# Fixed "ONLINE" and "OFFLINE" events
* Improved SEARCHFILES command to work on non-standard screens
03/29/10
+ Venice5 DAB/FM Radio module
+ PLabs Digital Car Radio FM Radio Module
03/28/10
# SkinTool.dll enable not supported fixed
# SkinEditor setting labels to bold when not told so
+ "SETVARFROMVAR" - use a variable within another variable's name
03/26/10
* Improved Windows 2000/XP mixer support to update mixer immediately upon outside changes
+ [WINDOWS 9x ONLY] SETTING/USERVAR: "MIXERREFRESH=x", where x = 1 to 50 (time in 10ths of a second)
this is the rate at which mixer levels/mutes are polled from system. The default is 30 (3 seconds).
* Removed the absolute path to skin, in resume.ini, since skins are in the "SKINS" directory
(absolute paths have not been needed in rr.ini for a long time now, so this now matches)
03/21/10
! Performace improvement: When using "Winamp Line-In Plugin" for any source; Radio, XM, Sirius, A new secondary instance of Winamp is used.
03/18/10
# Issue with the CTRL RIGHT/LEFT not selecting next/prev control
# Improved iList support to auto-add non-gesture area
