Results 1 to 9 of 9
Thread: Byind & exists
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Byind & exists
    Does anyone know if I can use the "EXISTS" dynamic indicator code with the BYIND command.
    Basically this is the code I'm trying to get working, but can't for some reason.
    "BYIND;EXISTS;$SKINPATH$TEST.BAT;=Yes<<=No"
    Thanks in advance ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Again with these interesting mix of features..
    This should work if you don't use ";" with exists ( ; is the correct way), try using : instead:
    "BYIND;EXISTS:$SKINPATH$TEST.BAT;=Yes<<=No"
    This will LIKELY work..
    Ride Runner RR's Myspace
    Jul 2007
    Ireland
    Well sure there is no point in asking easy questions ...
    I really hoped that command would work, but no joy. It will work as a regular IND command but not inside the BYIND command. So back to the drawing board ... lol
    Thanks.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This should have worked.. let me try it out and let you know..
    Jul 2007
    Ireland
    thanks guino.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I think I found the issue... write the word EXISTS in lower case like (already fixed code):
    "BYIND;exisits:$SKINPATH$TEST.BAT;=Yes<<=No"
    Jul 2007
    Ireland
    Works perfect ... thank you sir.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Valheru View Post
    should have worked the first time too if there wasn't a sneaky bug in there..
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Learn something new everyday w/ this FE.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  1. Jeep WJ on dash LCD consolle..it exists!
    By CherokeeChief in forum LCD/Display
    Last Post: 03-09-2009, 10:21 AM
  2. Replies: 6
    Last Post: 03-29-2008, 11:48 AM
  3. Replies: 27
    Last Post: 01-19-2008, 08:57 AM
  4. Does anyone know if something like this exists?
    By AYahoo in forum General Hardware Discussion
    Last Post: 02-05-2005, 09:52 PM
