Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: A few 'issues'.
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    A few 'issues'.
    I've had a few problems with the last 2 releases. 3/1- the line-in will not unmute, even though I have it checked in config. I have to go into the EQ screen and click the line-in button a few times, then it stays on and works. BUT, sometimes the music (MP3's) will play along with the radio. I have to pause the MP3.
    Also, pre-load screen will not load or stay in the RR.ini after turning off the computer. I have to run config and set them again.
    With the 4/1 release, same issues but now the CPU usage is way up around 60%, as where with 3/1 it was around 10% or less.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    MySQL Error
    Oct 2004
    something on your machine....
    no major changes in the release
    why would the line-in unmute anyway? the only way it would if something asks it to
    sounds like something it writing to your rr.ini (rr wont do that on its own)
    cpu% flash issues... are u at the latest flash? see sticky
    usually 1st thing i say, is use carwings_dynamic_lite
    (this time its not the 1st thing... but still applies)
    also.. before you say i have it checked in rrconfig... id look at rr.ini directly in text editor
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Mitch
    This would normally be the que for E to suggest his "notepad fix all" saying...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    MySQL Error
    Oct 2004
    hehe, well the other day someone insisted they didnt change anything in thier skin, only to find "resumemusic" was changed in rr.ini
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mar 2006
    Pennsylvania
    Ok, I'll check it with notepad.
    As for the line-in unmuting...it should be muted when you are using the music (MP3,etc) function and then unmute when you select the HD radio. But why would the MP3's still play when I'm using the radio? Since I got the new MB, it does this but have no idea why.
    Thanks.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    MySQL Error
    Oct 2004
    Quote Originally Posted by PontiacGA View Post
    Thanks.
    hard to say why(skin names is one reason)... you asking me to answer that blind folded..
    try enlighting me, post a debug.txt of the session using carwings_dynamic_lite
    and post your rr.ini
    oh, when i say post... i mean attach
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mar 2006
    Pennsylvania
    Ok, the preload screen is fixed and so is the CPU usage issue. I thought I installed 10.
    Heres those files. I usually use DFX 4.0, but switched to the FE you asked for.
    Attached Files Attached Files
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    MySQL Error
    Oct 2004
    so using carwings dynamic, going from radio to mp3s, does radio mute?
    its hard to argue with the log
    4/8/2010 10:09:42 AM: Executing: Audio
    4/8/2010 10:09:42 AM: HDRadio---> RadioActive: Active = false
    4/8/2010 10:09:42 AM: HDRadio---> RadioActive: Active = false, .MuteOn
    one thing you're using the line in plug in...
    but WMPRR, which of course doesnt have that...
    id set
    uselineinplugin=false
    thats gonna open a few issues
    maybe not... we do have some safety checks
    try that, and let me know...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mar 2006
    Pennsylvania
    No problem with the radio muting when going to MP3's. Just vice versa.
    I'll try that then and let ya know. Thanks again.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  1. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 09:31 PM
  2. Device Issues / Hibernation Issues / and Screen Question!
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 01-09-2008, 04:46 PM
  3. Got my G4 installed...few issues...
    By twenty8eight in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 10-23-2007, 12:11 AM
  4. Touchscreen Issues w/Hibernation & CNX-P1290
    By jmciver in forum Power Supplies
    Last Post: 12-20-2006, 08:48 PM
  5. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 02:16 PM
