Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: GPS causes RR to lock up
  1. #11
    Apr 2010
    Bit more of an update:
    • I searched for zips.dll and that wasn't there
    • I did the full uninstall, reboot and reinstall of flash10 though ie and still have the same issue
    • I uninstalled, rebooted and installed flash8 as per this but when I started RR with DigitalFX the clock and the guages looked terrible (blockly, sections missing etc.) I didn't get to test if that would fix the hanging problem as it would have been an unusable solution.
    So looks like Flash8 is too old and Flash10 causes the hanging problems, according to the DigitalFX guide "You can also reduce your hardware acceleration, and this has helped cure the flash problem for many people." so I'll give that a try next. I'm open to any other ideas
  2. #12
    MySQL Error
    Oct 2004
    FLASH8??
    just use the installer in the sticky
    http://www.mp3car.com/vbulletin/road...sh-10-now.html
    and maybe its 1 flash element in digitialFX4 (god that skin, so help us)
    try to narrow down the issue... try another skin, other skin with flash, but not that one
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #13
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Addition to Mitch's
    I'd keep things simple till you figure out the issue, like only use RR is connected to the GPS com port.
    Try the default RR Carwings skin (has no flash but would tell is that is part of the problem or not)
    You never said if you looked at this from Johns posting:
    Also, you can check for the "Locate=xxx" in the rr and skin.ini's. If you find this line, delete it as well and test again.
    Also, if it still freezes, run RR a few times, noting the time between you start RR and when it freezes to see if its consistently around the same time frame.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #14
    Apr 2010
    Right, thanks for the input, I'm back with more info!
    • I can't find a Locate= anywhere in a skin.ini
    • It does it with the crystalSilver and the Beta skin too
    • It only happens if the GPS is connected and a port selected
    • The guages do work before it hangs
    • You don't have to go to the guages for it to hang
    • The time to hang is rough about 30-40secs
    • I've swicted off hardware acc.,
    • There is only one port occupied
    • I'm running Flash 10,0,45,2
    Hope someone can shed more light on this!
  5. #15
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    try another gps splitter like GPSGATE.. download the demo version or the cracked one (if you want to go to jail )
  6. #16
    Apr 2010
    Quote Originally Posted by Nomader View Post
    To narrow down the problem I've removed the software port splitter, so I don't think it's xport causing the trouble.
  7. #17
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The "Locate" setting would most likely be in the rr.ini file. Trying to brainstorm what else you can check or change....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #18
    Apr 2010
    Talking
    Wooo! Got it working, many thanks for all the help:
    Quote Originally Posted by JohnWPB View Post
    Look for "zips.dll" in the RR folder, if it is there DELETE IT! I would do a search of the entire RR folder, and sub folders as well.
    There wasn't a zips.dll, but there was a zips.dat, I deleted that and I'm back running again, maybe it was polling that and as I'm not in the US I was outside it's range and had some issues.
  9. #19
    Jul 2007
    Hi, i've encountered the same problem, but these things doesn't help me. The cpu is at 60% when it freezes. And i cant fint any files with zips in it. And there is no line in any .ini files called locate.
    Anybody got an idea?
  1. W3bLock - Screen Lock w/ GPS Tracking
    By W3bMa5t3r in forum RR Plugins
    Last Post: 07-17-2008, 08:09 AM
  2. W3bTrackerRR - W3bTracker GPS Tracking RR Plugin
    Last Post: 07-04-2008, 01:32 AM
  3. iGuidance GPS Issue in RR
    By moeman_49 in forum GPS
    Last Post: 06-04-2006, 03:17 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
