Results 1 to 10 of 19
Thread: Latest RR problem with Album art
    May 2006
    Markham, Ontario, Canada
    Dear all,
    The album art no longer shows on RR with recent version (I remember they used to work in 2009 release). I have read the FAQ and following the instruction to name them folder.jpg in every album folders under the artist's folder. The jpg files are all non-hidden and not read-only. I have tried different skins and all have the same problem. Please helps. Thanks in advance.
    Jguy
    MySQL Error
    Oct 2004
    approved the post
    this is for sure not the case
    you provide no real information...
    the RR version, the OS and so fourth
    Album art is working fine, if you are using the mp3art plugin, for embedded artwork.. i would uninstall that, and get the newest
    also in rr.ini
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2006
    I am using Windows 7 32-bit, RR is the April release. It's a fresh install because I was running 64-bit of Windows 7 and I thought it's why I got problem with it. I used to able to see the album art prior to 2010 release. The jpg are not embedded and I put the image together with the MP3's. The rr.ini setting is what you're suggesting. I can post a screenshot if requires. Thanks.
    Jguy
    Quote Originally Posted by mitchjs View Post
    approved the post
    also in rr.ini
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    I have this issue too. Main PC and CarPC both running RR with exactly the same skin, same version, using same mp3s with same albumart files in the same folder locations. Main PC shows album art, CarPC doesn't. And I can't for the life of me work out where the difference lies.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Talking
    Be careful Mitch I have been proven wrong on a statement like that many time now hahah
    My Fiero Build Thread
    MySQL Error
    Oct 2004
    john, now now
    did u guys look at your coverfile setting in rr.ini?
    how about looking in Skin Tool, at the albumart indicator
    like
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    May 2006
    I have attached my rr.ini. I checked it using Skin Tool and it says contain no data at the audio player skin.
    john, now now
    like
    Attached Files Attached Files
    MySQL Error
    Oct 2004
    post a debug session too... cant even tell if media is playing
    if winamp is stopped and no track info is available, u get no albumart...
    also... post a rrpl.m3u8
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    how about some poorly programmed plugin, destroying albumart indicator
    thats why i need to see a debug.txt of a session!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    some questions about album art itself.
    i see in some skins that the coder use the command....J,140,203,227,203 other use
    I,140,203,227,203,"ALBUMART"
    what makes the difference ?
    i thought the >J< command will show all arts, like radio, album, aso.
    and the >I< command will only show the "albumart"
    that was not true. its unimportant what command i code, it shows in both the same.
    another missunderstanding is the name "AlbumArt". as i translate it, i thought it shows me, like in older riderunner versions the pic which i integrate inside my mp3 file, if there is no pic inside...it shows the .jpg which is in the musicfolder ive opend.
    momentary i cant see the pic which is in my musicfolder.
    so, as i read your notes, and i see whats happend on my screen...i MUST give every mp3 file a pic, otherwise i see an empty field.
    dont say i must give every mp3 file a pic.
  1. More on Album Art (bug/feature request)
    By unlfrank in forum Freeway
    Last Post: 12-28-2006, 12:58 PM
  2. Question about Album art browsing
    By JohnWPB in forum Road Runner
    Last Post: 08-28-2006, 02:21 PM
  3. Album art downloader
    By hijinks21 in forum Software & Software Development
    Last Post: 07-20-2006, 10:56 AM
  4. Album art problem
    By lucianop in forum Road Runner
    Last Post: 06-04-2006, 02:00 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
