Results 1 to 6 of 6
Thread: XM Radio with XM Direct and roadrunner
    Variable Bitrate miwise's Avatar
    Sep 2006
    Got xm on riderunner running. I figured out that the usb interface must be just that. An interface. Meaning the xm direct box must be plugged in to get riderunner to acknowledge it. I'm assuming the mp3car box is just a custom serial interface box.
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
    Jun 2003
    Memphis - TN
    I believe so. Just be forewarned if you have the car2PC adapter, they use the same chipset and do not work together. Atleast mine didnt.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    MySQL Error
    Oct 2004
    they do... its because the xm interface is using older drivers
    and causing files to be mixed up
    need to install the one that uses the newest drivers last
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Sep 2006
    My xm direct reciever stopped putting out sound. Also, it seems that I have to unplug and replug in the reciever to make it work at times (at least in its limited capacity). It shows what's playing on the radio, but I can't hear anything playing. You think its the tuner or the usb interface box?
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    MySQL Error
    Oct 2004
    not the usb box...
    but i would test it all with my XM Interface demo
    you wont hear anything, unless you tell windows to allow you to hear
    ie... un mute line in, or capture the audio
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2006
    Quote Originally Posted by mitchjs View Post
    not the usb box...
    Right. I tried testing the box. When it did work I noticed the audio would stop when I close roadrunner. Even when I plugged the audio lines straight into my tv (of course the data connection was still plugged into computer). This is how I tested it. It seems to erratically sometimes not detect the xm reciever unless I unplug and replug everything. I sent the adapter into mp3car for testing last week. I'm about to send the xm box to audiovox for repairs as well
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
  1. Replies: 42
    Last Post: 12-11-2009, 03:36 PM
  2. radioSHARK Plugin for RoadRunner
    By Evolution VIII in forum RR Plugins
    Last Post: 09-30-2007, 06:55 PM
  3. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  4. FS: Xm Cables, XM Home Cable, USB-Serial Adapters
    By Legarcondemerde in forum Classified Archive
    Last Post: 07-08-2006, 07:15 PM
  5. XM Direct problem
    By McFreak in forum Hardware Development
    Last Post: 06-18-2005, 07:45 PM
