Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Display the Status of a Custom Indicator as Text?
  1. #11
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ok, here is my much more organized version that has been fully tested and works!
    Add "WinPresetLoad" to the skins "ONSKINSTART" cmd
    Change your button cmd to:
    Code:
    B5,500,526,100,74,"WinPresetToggle"
    Change your label to:
    Code:
     L6,516,527,71,50,#DFX1R#,#DFX1G#,#DFX1B#,20,"Nissan:B","=$WinVolLabel$","CENTER"
    Put in either RR's or skin's 'Exectbl.ini' file
    Code:
    /-- Main Cmds
    "WinPresetToggle","BYVAR;WinPresetLoaded;WinDnVolPreset<<WinUpVolPreset"
    "WinPresetLoad","SETVAR;speedattmode;line||SAVETOINI;speedattmode;line||SETVAR;speedattmaxstep;15||SAVETOINI;speedattmaxstep;15||SETVAR;speedattspeeda;0||BYVAR;WinPresetLoaded;WinUpVolPreset<<WinDnVolPreset"
    / Preset#0
    "WinUpVolPreset","SETVAR;WinPresetLoaded;0||SAVETOINI;WinPresetLoaded;0||SETVAR;WinVolLabel;OFF||SAVETOINI;WinVolLabel;OFF||SETIND;!WINDOW;OFF||SETVAR;speedatt;$p1speedatt$||SETVAR;speedattmute;$p1speedattmute$||SETVAR;speedattunit;$p1speedattunit$||SETVAR;speedattvola;$p1speedattvola$||SETVAR;speedattvolb;$p1speedattvolb$||SETVAR;speedattspeedb;$p1speedattspeedb$"
    / Preset#1
    "WinDnVolPreset","SETVAR;WinPresetLoaded;1||SAVETOINI;WinPresetLoaded;1||SETVAR;WinVolLabel;ON||SAVETOINI;WinVolLabel;ON||SETIND;!WINDOW;ON||SETVAR;speedatt;$p2speedatt$||SETVAR;speedattmute;$p2speedattmute$||SETVAR;speedattunit;$p2speedattunit$||SETVAR;speedattvola;$p2speedattvola$||SETVAR;speedattvolb;$p2speedattvolb$||SETVAR;speedattspeedb;$p2speedattspeedb$"
    Add or set in 'rr.ini' ( the mute's and unit's i was unsure of so you can fill those in )
    Code:
    /-- Saved State
    WinPresetLoaded=0
    /-- Button Txt
    WinVolLabel=OFF
    /-- preset#1
    p1speedatt=True
    p1speedattmute=
    p1speedattunit=
    p1speedattvola=65
    p1speedattvolb=100
    p1speedattspeeda=0
    p1speedattspeedb=80
    /-- preset#2
    p2speedatt=True
    p2speedattmute=
    p2speedattunit=
    p2speedattvola=40
    p2speedattvolb=100
    p2speedattspeeda=0
    p2speedattspeedb=50
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #12
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Hey Blue,
    This works great. You must enjoy challenges. My only problem is that on my system, the volume always comes back at 50% whether in the ON or OFF state on exit. First button press it does correct itself to the next correct state. Any ideas.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  3. #13
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Seeing that every value is written to rr.ini, and when RR loads any values in a skin.ini will overider the rr.ini ones. Recheck your skin ini for any of those values, and delete them if found. This is really the only thing that could be causing this odd effect.
    My Testing was on my DT w/o any gps, so as soon as i start up RR, its already set the vol to the correctly loaded preset, and pressing the btn, the vol raises/lowers to proper levels.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #14
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    That is kind of what I thought. I will go through the ini files carefully.
    By the way. Much thanks are in order for helping with this. I know you program a lot of things from scratch, where I am more of a copy and paste type, but I go over the methods to learn as much as I can.
    So Thanks for the help.
    Edit: So the solution seems to be that all of this button stuff overrides the built in GPS Speed Attenuation, so i went into the RRConfig and disabled it. That was where the 50% was coming from. RR now opens with the correct last set volume.
    Edit 2: Okay so this was boneheaded. The above edit about the built in GPS Speed was incorrect. What the solution was, is that I did not follow directions, and forgot to add the ONSKINSTART command "WinPresetLoad"
    Okay next question. The double bar "||" I know is used to seperate code items in RR. The font I want to use on this button uses a single bar. However that puts three bars next to each other in the code. Is there a way to seperate the single bar I actually want to use for the font "|" from the double bar "||" code seperation.
  5. #15
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Post your example
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #16
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    From your code above, instead of saying ON or OFF it would be | or \ in the appropriate places.
    The font I want to use has the symbols on those keys, and I didnt want to create a custom font.
    SETVAR;WinVolLabel;"|"||SAVETOINI;WinVolLabel;"|"| |SETIND;!WINDOW;ON||
    SETVAR;WinVolLabel;"\"||SAVETOINI;WinVolLabel;"\"| |SETIND;!WINDOW;OFF||
    With the single bar or slash in quotes. I had this almost working for a minute last night, but now dont remember which one of the parts needed the bar or slash either.
    Edit: Never mind. I figured it out. I just put any key between the bar and double bar and then made my text box only big enough for the text I wanted displayed. And yes the quotes are only there to show the key stroke, not actually in the code.
  7. #17
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Okay, I have been using this successfully for 2 years since the last post on the thread. It is now time to upgrade to Windows 7, and although I have changed nothing in the coding, it is not working.
    Any guidance. I am looking myself, but am probably missing something. The GPS volume settings included in DFX 5.2 are changing the volume, but my custom button settings are not changing the volume at all.
    Thanks.
    EDIT: Never mind. I commented out the GPS volume settings included in DFX and my settings now work.
  1. BBcode
    By optikalefx in forum VaultWiki
    Last Post: 08-13-2009, 10:43 AM
  2. Custom AM/FM radio display?
    By ShinkunoNamida in forum General Hardware Discussion
    Last Post: 02-25-2003, 07:28 PM
  3. Replies: 0
    Last Post: 02-11-2003, 01:15 PM
  4. cd text display?
    By meyer64 in forum General Hardware Discussion
    Last Post: 09-23-2002, 10:41 AM
  5. Control things and display status of things
    By All4Norway in forum General Hardware Discussion
    Last Post: 07-18-2002, 01:32 PM
