Page 1 of 6 123456 LastLast
Results 1 to 10 of 59
Thread: RR 05-01-2010 Release
    MySQL Error
    Oct 2004
    May 2010 Release
    Download from: here
    Some new features in this release (not kidding this time), and a few bug fixes
    Highlights:
    • Skin Command; "VISULOAD;vis_xxx.dll;xxxwindow" sets winamp visualization plug-in.
    • Fixed ALBUMART images can be in unicode folder names.
    • Fixed "Slowness" with some ID3 V2.2 tags
    Thanks to:
    Nomader for his relentless testing...
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    04/30/10
    * Improved Blinking Indicator Performance (Less CPU Load on slower machines)
    + Plugins: added Unload method, called before a plugin is Unloaded
    04/27/10
    + Skincommand "MUTE;linename" now has optional 3rd param "true/false"
      "MUTE;CD Audio;TRUE" - mutes
      "MUTE;CD Audio;FALSE" - un-mutes
      "MUTE;CD Audio" - toggles mute state
    04/26/10
    # Fixed ALBUMART images can be in unicode folder names.
    04/25/10
    # Fixed freezing when a "RELOADSKIN||LOAD;Menu.skin" cmd issued when on the menu screen
    * Added "uselineinsingleinstance" and "disableDC" settings to config
    04/19/10
    + Added "SetErrorScr" cmd, exposes the error screen for external apps and/or unfinished skin sections
    04/18/10
    # Fixed Opacity setting for VISUals, "opacityvisu" setting/uservar is now used
    # If error occurs during RR start up, MessageBox will be visable on top of splash screen
    04/16/10
    # Fixed Application Image not shown on Launch screen for some settings
    + Skin Command; "VISULOAD;vis_xxx.dll;xxxwindow"
      ex; "visuload;vis_satan.dll;!attachanalyser!Classic"
      "visuload;vis_milk2.dll;MilkDrop"
      "visuload;vis_avs.dll;!Winamp Gen!AVS"
      if visu is already on, the new one will start immediately, otherwise "VISU" command as normal to toggle on/off
    04/14/10
    # Fixed "RTUNE" command to allow comma system ex: "RTUNE;95,1"
    04/13/10
    + Setting; "USELINEINSINGLEINSTANCE=true/false", defaults to false
      (false = will use 2 instances of winamp, 1 for mp3s, the other for the LINE-IN Plug-in)
    04/10/10
    + "ICO" list item definition to custom list load/save commands, used to load both text and icon info for each line loaded
    	("ICO" definition line MUST follow the "LST" item line for that item)
    	also supports usage of vars for path/files
    * Improved SCREENSHOT command to also save any transparent layers over the screen
    04/07/10
    + Setting; "DISABLEDC=true/false", disables Desktop Compositioning for windows Vista/Win7 ONLY
      (only needed if you are using transitions and feel its better with DC Disabled)
    04/06/10
    # Fixed "Slowness" with some ID3 V2.2 tags
    + Additional mixer lines available in (Vista/Win7 only) (see debug.txt or vista mixer explorer.exe for list)
    04/03/10
    # "ONLINE" & "OFFLINE" events can work without depending on "ONLINE" indicator
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Thanks for this new version and these new features !
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    I believe that there is a problem with transparent VISUALS. I am getting a black background with all visuals. It was working fine with April's release. I have the same settings as April's for May's.
    MySQL Error
    Oct 2004
    there has been a change... (read history)
    you need to be way more specfic
    the old code had screensaver transparency and avs transparency tied together
    check your rr.ini settings
    not to mention at runtime, with skintool, look at transparentvisu variable
    case a skini.ini set it to false or such...
    mine are:
    transparentvisu=true
    opacityvisu=40
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    i just noticed for AVS, the opacityvisu value, is oddly divide by 2.55
    so its not exactly 0 - 100%
    I'm gonna remove that, since it makes no sense
    this 2.55 only comes into play for AVS visual
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Got it working, thanks.
    May 2008
    Bordeaux, France
    Smile Skintool issue
    Actualy, the 2.1.3 skintool and before also, don't save the variable , label, indicator into the combo list .
    Is it possible to add this feature for the June version ?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    They already should, if the command ones are saving then so should the bottom portion.
    I have no problems with them on this end.
    You should have a 'Default+SkinTool' file in the skintool folder, its where its saving the data to.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    MySQL Error
    Oct 2004
    Quote Originally Posted by suavecito View Post
    you know, you should at least say what you did, so others can benefit, just in case someone else in the world has your exact issue
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    May 2008
    Bordeaux, France
    It's not the command that i hope to backup, this is the variable combo who are empty for me (xp sp3).
  1. RR 11/01/2009 Release
    By mitchjs in forum Road Runner
    Last Post: 11-28-2009, 09:11 AM
  2. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 08:48 PM
  3. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  4. RR 05-28-05.. Early Release..
    By guino in forum Road Runner
    Last Post: 06-04-2005, 09:36 PM
  5. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 01:27 PM
