Page 2 of 9 FirstFirst 123456789 LastLast
Results 11 to 20 of 89
Thread: minicam container for embedding
  1. #11
    Nov 2006
    yonu,
    Nice, simple piece of work, well done.
    Have you updated the source you posted when you included full-screen support?
    Were did you download minicam from?
    And what cameras does it support?
    Regards,
    Jim
  2. #12
    Jan 2005
    well minicam can be downloaded from http://curioustech.home.insightbb.com/xport.html which is Curiosity's site as they designed minicam and nope i haven't updated the source code as the changes were made to minicam not the container I posted and as far as I know minicam will work with any WDM camera
  3. #13
    Nov 2006
    yonu,
    Thanks for the info. I've downloaded minicaml and I am in the process of playing with it natively with one camera and already have a couple of questions:
    1. Once in full-screen, how does one get back to the small image?
    2. where does minicam store its settings?
    Once I've played with it a bit, I'll give it the acid test. A four camera setup using 4 of the same cameras that no other package seems to be able to run successfully all at the same time. I can get 2 and sometimes 3 on a good day. I've tried at least 4 different packages, in 3 cases I tried multiple instances of a single app and the 4th proported to support all four at the same time. Interestingly, all of the cameras work fine if I only use then one at a time.
    So I ended up writing an AutoIt app that displayed each of the cameras in a rotation where I dynamically changed the active camera in the program. I used AmCap for the camera support.
    Therefore, I am quite interested to see if minicam will do as I want (4 at once) with my cameras (4 $16.95 el cheapos).
    Regards,
    Jim
  4. #14
    Jan 2005
    what is the verdict on 4 cams at once the nost i have tryed is 2 so far as I am still deciding on the locations of the last 2 cams
  5. #15
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Maybe you should write a 2 cam version.
    @obrienj Fullscreen toggle is either double click anywhere or ESC key.
  6. #16
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    do you guys record all the 4 cams?? what about CPU usage..i am having trouble recording just one!!
  7. #17
    Nov 2006
    Curiosity,
    I don't understand what is going on but double-click does nothing and ESC closes the minicam program.
    I'm running Vista Home Premium SP2.
    Regards,
    Jim
  8. #18
    Nov 2006
    yonu,
    Due to other commitments, it may be a couple of weeks before I get to try your app and minicam with 4 cameras, but I have my doubts as the problem I have had appears to be a poorly behaved device driver or a set of "identical" devices that don't present unique ids.
    But I'll dig into that later.
    Regards,
    Jim
  9. #19
    Jan 2005
    ok I may throw it onto my house server and see what happens then as I use 15 webcams as part of my home security system and 8 of them are the cheap ebay ones all the same models
  10. #20
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by obrienj View Post
    Curiosity,
    Regards,
    Jim
    OK, well I knew ESC did something. F works to toggle fullscreen from any mode, and the double-click may not work if it's too fast or you move.
  1. embed minicam
    By yonu in forum Road Runner
    Last Post: 01-24-2010, 10:58 AM
  2. open container question
    By Peoples in forum Off Topic
    Last Post: 05-26-2005, 04:30 PM
  3. sealed container?
    By dannn in forum Power Supplies
    Last Post: 08-22-2004, 08:57 PM
