Results 1 to 10 of 14
Thread: help code
    Low Bitrate topjohn's Avatar
    Oct 2009
    France /Wissous
    help code
    Hello
    I want to get a file name (without extant), only when I use the function "SETVARBYCODE; LISTTEXT; LISTTEXT" and I put in a txt file with the "WriteToFile; $SKINPATH$example.txt;= $LISTTEXT$"
    He writes in the file "toto.pdf," I only wish he just writes "toto"
    Is there a solution?
    Thank you.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    What you can do is before you load the screen that has the list on it is to set the "showextensions" setting to false like so:
    "SETVAR;showextensions;false||load;xxx.skin"
    Then the list will not show any extensions of files. You can also of course set the setting back to true when you leave the scrn, as to not effect other scrn list properties.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Oct 2009
    France /Wissous
    thank you for the reply,
    I just tried, but it does not work.
    I always see the extensions.
    I also tried [SD, 00,00,32,32,"C:\WINDOWS\Fonts","*.ttf ",FALSE] but it changes nothing, I always see the extensions .ttf
    Oct 2009
    France /Wissous
    Well, I went bya. bat file to solve my problem.
    Thank you anyway for the help.
    Oct 2009
    France /Wissous
    Hello
    how to get back on a predefined selection in a textbox after a RELOADSCREEN
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    R I asking how to reselect the txt box ctrl or something different?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Oct 2009
    France /Wissous
    I do not understand what you ask me.
    My problem is to return to the selection chosen before the reloadscreen, because he returned to the top.
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Avez vous lancé cette commande avant le chargement de votre écran ?
    Oct 2009
    France /Wissous
    Bonjour pierro,
    ça c'était pour le problème d'extention après les nom de fichier, j'avais essayé cette option mais les extentions apparaissent tjrs, j'ai donc fait avec.
    Mon nouveau problème, c'est je voudrais revenir sur le texte en surbrillance qui était selectionnait avant que je fasse mon reloadscreen.
    En fait je suis en train de faire un skin pour créer une selection de font, pour ce faire je vais dans le répertoire "fonts" de windows, il me liste donc toutes les polices au format TTF, enssuite j'ai créé un .bat qui va me trouver le vrai nom de la police d'après le nom.TTF, jusque la, ça fonctionne impécable.
    Seulement quand je veux fair un aperçu de la police sélectionné, que je fait donc un reloadscreen pour que mon texte s'affiche, il me remet au début de la liste des TTF, moi je voudrais lui dire qu'il place dans une variable le N° ou le nom du fichier dans la liste et qu'il me replace au même endroit après le reload, afin de ne pas me retaper toute la liste pour retrouver la police qui m'avait convenu pour pouvoir l'appliquer au skin.
    Je tourne en rond avec la fonction CLLOAD, mais si ça se trouve ce n'est pas cette fonction qu'il faut utiliser, ou alors je n'arrive pas a l'utiliser correctement.
    Je ne sais pas si j'ai été claire
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. unlock code
    By slrpro02 in forum Wireless Communications
    Last Post: 12-28-2007, 06:55 PM
  2. Source code bugged
    By Saldorri in forum Media Engine
    Last Post: 07-29-2005, 09:23 AM
  3. Head Unit 'code' - help!
    By Laidback in forum Car Audio
    Last Post: 06-10-2005, 09:53 AM
