Results 11 to 20 of 28
Thread: RR 06-01-2010 Release
  1. #11
    Aug 2004
    Germany
    3=USB ? Would make sense for me. Or is there already a command for that ? Didn't check, because I don't need it.
  2. #12
    MySQL Error
    Oct 2004
    USB device arrival is quite different than media inserted into a CD/DVD drive
    beyond the scope
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #13
    Feb 2006
    TV/Camera support
    Hi
    I saw the description of the new version of RR, there is a "TV/Camera support".
    Could you tell me if this is a support to DVBT? And, how can I enable it?
    Thanks in advance!
  4. #14
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by vinchan View Post
    Hi
    Thanks in advance!
    TV/Camera support has always been thru the Winamp TV plugin -- some versions do have some support DVBT. It's not the most practical thing but it works for some people. Generally the best thing still is to embed the application of the manufacturer, but from what I understand DVBT reception is very poor while moving (so not a great thing in the car) -- only some Diversity Tuners do better at that.
    Ride Runner RR's Myspace
  5. #15
    Newbie piglith's Avatar
    May 2008
    Think I found the problem with AVS Transparency. I didn't have the problem with March Release, Never got around to installing the April and installed the June. AVS refused to go transparent.
    I have a Netbook with RR on and just updated it. Same thing. No transparency. After reading few posts on the rr.ini. I modified it on the Netbook. It works again. I thought it was the RRConfig program not changing the variable. Tested that and no change.
    Then thought maybe it was the version of RRConfig not getting updated.
    The version I have is 1.0.2.7.
    So I installed virgin RR on this computer and configured with transparency AVS. Checked the INI and nothing changed. Still set at false and no change in value. Opened RRConfig and values are changed there.
    So what seems to be happening is how ever RR configured the settings are stored but not written to the INI (At least for AVS ). Am I correct with this?
    Running RR on Windows7-64
  6. #16
    MySQL Error
    Oct 2004
    its possible... rrconfig is massive on its own... i think its just changing a old setting
    the proper rr.ini setting is:
    transparentvisu=true
    (for transparent)
    looking at RRConfig, its visualization settings is incorrect... we'll fix it up...
    just edit rr.ini
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #17
    May 2008
    Yes that is what fixed the problem. I haven't tested other settings to see if the INI is getting updating yet. Running a Library backup. When its done Ill look to see if it is. However I think if you change the INI and re-save from RRConfig it will revert back to false.
    Changes in RRConfig for music page 2 'AVS' are not updating the INI
    If you edit the rr.ini by hand and set to true and Make any change using RRConfig and save it will revert back to false
    Other Items seem to be working fine
  8. #18
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    Quote Originally Posted by pierrotm777 View Post
    ONMEDIAINSERT, replace Medialaunch script ?
    Not fully i think !
    Thanks for this new version
    Could replace for some installs. Medialaunch looks for video/audio content regardless of media type. I just use USB for movies and mp3's. I would really like to see that functionality in RR natively. USB drives are cheap and small.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  9. #19
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by chevyn8 View Post
    In fact
  10. #20
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    One weird thing I've stumbled across tonight, and haven't really checked in the car yet, so this is just on my test/build setup.
    I've got to click the vis button 3 times to get it to show up properly. I just did a fresh install of RR 6-10, and updated flash along with some other windows updates. Checked this with my skin as well as carwings. I'm running Winamp 2.95.
    1 click does nothing
    2 clicks loads AVS vis, but not transparent or embeded
    3 clicks embeds the vis and makes it transparent
    4th click closes vis, then needs 3 more clicks to start again.
    Am I missing something? I know there was a change dealing with the transparency, did this perhaps affect the rest?
    Here's a snippet from my debug - which doesn't seem to show much to me.
    6/23/2010 9:50:26 PM: Executing: Audio
    6/23/2010 9:50:27 PM: CheckResume: ResumeMusic=2 WasRadio=0
    6/23/2010 9:50:27 PM: Enter Exec: True, audio_player.skin, , False
    6/23/2010 9:50:27 PM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
    6/23/2010 9:50:27 PM: Leave Exec: False, audio_player.skin, ONSCREENCHANGE, False
    6/23/2010 9:50:31 PM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||PLAY", False
    6/23/2010 9:50:31 PM: Que Exec: True, audio_player.skin, "ONBTNPRESS||PLAY", False
    6/23/2010 9:50:31 PM: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    6/23/2010 9:50:31 PM: Executing: PlaySound;C:\Program Files\RideRunner\Skins\Carwings_dynamic_lite\Sound s\button1.wav
    6/23/2010 9:50:31 PM: Que Exec: True, audio_player.skin, "PLAY", False
    6/23/2010 9:50:31 PM: Executing: PLAY
    6/23/2010 9:50:31 PM: Leave Exec: False, audio_player.skin, play, False
    6/23/2010 9:50:35 PM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VISU", False
    6/23/2010 9:50:35 PM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VISU", False
    6/23/2010 9:50:35 PM: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    6/23/2010 9:50:35 PM: Executing: PlaySound;C:\Program Files\RideRunner\Skins\Carwings_dynamic_lite\Sound s\button1.wav
    6/23/2010 9:50:35 PM: Que Exec: True, audio_player.skin, "VISU", False
    6/23/2010 9:50:35 PM: Executing: VISU
    6/23/2010 9:50:35 PM: Leave Exec: False, audio_player.skin, VISU, False
    6/23/2010 9:50:38 PM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VISU", False
    6/23/2010 9:50:38 PM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VISU", False
    6/23/2010 9:50:38 PM: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    6/23/2010 9:50:38 PM: Executing: PlaySound;C:\Program Files\RideRunner\Skins\Carwings_dynamic_lite\Sound s\button1.wav
    6/23/2010 9:50:38 PM: Que Exec: True, audio_player.skin, "VISU", False
    6/23/2010 9:50:38 PM: Executing: VISU
    6/23/2010 9:50:38 PM: Leave Exec: False, audio_player.skin, VISU, False
    6/23/2010 9:50:42 PM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VISU", False
    6/23/2010 9:50:42 PM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VISU", False
    6/23/2010 9:50:42 PM: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    6/23/2010 9:50:42 PM: Executing: PlaySound;C:\Program Files\RideRunner\Skins\Carwings_dynamic_lite\Sound s\button1.wav
    6/23/2010 9:50:42 PM: Que Exec: True, audio_player.skin, "VISU", False
    6/23/2010 9:50:42 PM: Executing: VISU
    6/23/2010 9:50:42 PM: Leave Exec: False, audio_player.skin, VISU, False
    6/23/2010 9:50:47 PM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||EXIT", False
    6/23/2010 9:50:47 PM: Que Exec: True, audio_player.skin, "ONBTNPRESS||EXIT", False
    6/23/2010 9:50:47 PM: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    6/23/2010 9:50:47 PM: Executing: PlaySound;C:\Program Files\RideRunner\Skins\Carwings_dynamic_lite\Sound s\button1.wav
    6/23/2010 9:50:47 PM: Que Exec: True, audio_player.skin, "EXIT", False
    6/23/2010 9:50:47 PM: Executing: EXIT
    in rr.ini I have transparentvisu=true (having to manually set it - which is known)
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  1. [REL] iGoBMW transparent
    By dan32500 in forum RR Released Skins
    Last Post: 02-27-2014, 01:25 PM
  2. RR 11/01/2009 Release
    By mitchjs in forum Road Runner
    Last Post: 11-28-2009, 09:11 AM
  3. RR trying to use MapPoint 06 as GPS
    By kenpojoe in forum Road Runner
    Last Post: 07-12-2006, 09:38 AM
  4. RR 05-28-05.. Early Release..
    By guino in forum Road Runner
    Last Post: 06-04-2005, 09:36 PM
  5. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 01:27 PM
