Results 21 to 30 of 37
Thread: TV support, is there any?
  1. #21
    Oct 2004
    Israel
    The Hauppauge diversity is controlled by the driver ( there is a little program from the company that lets you choose between diversity and dual tuner )
    A good app I'm using and it embed's quite good is Splash Lite
    http://mirillis.com/en/products/splash.html
    In the future they also plan to make a TV only version
    *My problem with VLC is that from my experience it crashes a lot when you have lousy reception , So it not really acceptable for car-pc usage..
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
  2. #22
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Quote Originally Posted by Madboy View Post
    some questions:
    1. what is the exact model of the stick? and how is no diversity compared to diversity, especially on the move?
    2.does it work with DVB viewer and winamp tv plugin?
    3. Are you sure it is driver controlled? this sounds good!!
  3. #23
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Small prog called Diversity Tool comes with installation cd, you can select either diversity or dual tuner. If you select diversity then only one device appear to devise manager or if you select dual tuner then two devices appear to device manager.
  4. #24
    Apr 2006
    Greece
    Quote Originally Posted by Dartman_71 View Post
    and how's the reception on the move?
  5. #25
    Feb 2009
    Finland
    Small correction to my previous post. When in dual tuner mode, second device appear to DVB Viewer's device options when pressing find devices. DVB Viewer definately use diversity! Next step is to install Hauppauge in the car, more after the test drive.
  6. #26
    Oct 2004
    Israel
    I live in Israel
    Right now DVB-T is still in beta stage here
    So there are a lot of reception problems even when you stand still , Reception is better with a second antenna but still not perfect..
    On the move I can't see anything as of this moment - even with diversity
    I'm using NOVA-TD
    It works with DVBViewer but I don't think I managed to get it working with winamp's tv plugin
  7. #27
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Do you know this Tv software ?
    http://www.pouchintv.fr/
    This is a very light Tv TNT software. (use ffdshow)
    I try to embbed it into RR as soon as possible !
  8. #28
    Apr 2006
    Greece
    Quote Originally Posted by pierrotm777 View Post
    niceeeee....but in french
    you french always remind me of us greeks.. try to do everything in our language
    even if it sounds greek to most other people!!!
  9. #29
    May 2008
    Bordeaux, France
    Quote Originally Posted by Nomader View Post
    Yes but the program is also in english and you can to translate this page no ?
    In this forum all is in english , but if a program is very good but in an other language why don't try it ?
  10. #30
    Feb 2009
    Finland
    I am not satisfied to resption when on the move, but I didn't expect more from small antennas which came with the stick. Now it's modding time, I order two active +20dB antennas, I need to change connectors to fit Hauppauge of course. Those should be quite good antennas what I have read and in Youtube video 280km/h with no hiccup with car DVB-T receiver. I still have hi hopes because the reception is as good as the antennas. I'll be back after little tuning...
