Results 11 to 20 of 22
Thread: RR 07-01-2010 Release
  1. #11
    MySQL Error
    Oct 2004
    sargeants, hu?
    extra semicolon dont help
    "BYIND;VISU;<<VISU"
    if on, turn off
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    Dec 2008
    i reformatted yesterday and reinstalled a fresh copy of rr and dfx4. holy crap do things work better now... i mean holy crap its awesome that things actually work now....
  3. #13
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    Thanks Mitch - knew it had to be something simple that I was messing up.
    yea that's what I'm wanting - if on turn off
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  4. #14
    Jul 2008
    I hope this is the place to write this: i have problems now with AVS not embedding into RR
    Everything was fine 2 days ago, running winamp 2.95 and RR march - version.. Now updated RR to 7-1-2010 and the AVS is not embedding, it just keeps showing in a separate window on top what could be the trouble? i already try to configure it with RR Config, and after that i checked rr.ini and appears visuname=!Winamp Gen!AVS.. i'm not trying to make it transparent, just to embedd into a Axx,xx,xx area..
    Thanks for the help! keep the good work!
  5. #15
    MySQL Error
    Oct 2004
    i know that im embedding it currently into Carwings.. on the audio_player.skin
    my difference im using a much much newer winamp 5.572 (or something like that)
    remember with the A skin definition, you would have to TURN on VISU for it to embedd, if visu is already on, when you load a skin with a A definition, it wont embedd... unless that was the skin it was initially embedded on... if that all make sense...
    but.. hint hint... look at carwings skin for audio_player.skin
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #16
    Jul 2008
    thanks mitch for the reply, i understand what you say, i'm using my own modified version of simplistique, and from the audio_player.skin i call the visualization using a button with the command "VISU".. it has been always work ok, calling the visu and embedding properly in the A area, but after upgrading to RR 7-1-2010 it works the same way but the only problem is that it's not embedding..
    Maybe the problem is the winamp 2.95, i don't want to install a newer because i have the carputer very well optimized and don't want more cpu % load with a newer version of winamp.. o don't know if there is any difference on the load/memory/proccesing needs of a 5.13 vs 2.95? any knows?
  7. #17
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by drpriet View Post
    Using 5.13, CPU load hardly goes beyond 5% (playing music only)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  8. #18
    MySQL Error
    Oct 2004
    treetop, 5.13 is new, but old... and isnt even unicode compliant... im sure u dont have any unicode files being in GA, but might as well update to 5.5x... so many bugs back there
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #19
    Oct 2008
    Ontario, Canada
    winamp 2.95 is the issue
    I ran across this with June's release - guess I never posted that updating fixed it...
    RR 06-01-2010 Release
    Update winamp and all should be good. I didn't notice any jump in CPU, until I loaded a couple extra winamp plugins on and Those used up some CPU time.
  10. #20
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by mitchjs View Post
    Will do - Thanks.
    M2-ATX Power Supply
    Windows XP SP3
  1. RR 03-01-2010 Release
    By mitchjs in forum Road Runner
    Last Post: 04-14-2010, 09:22 AM
  2. RR 05-28-05.. Early Release..
    By guino in forum Road Runner
    Last Post: 06-04-2005, 08:36 PM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  4. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 12:27 PM
  5. News on the 07 version
    By netsuo in forum NeoCar Media Center
    Last Post: 11-06-2004, 09:01 PM
