Results 1 to 10 of 16
Thread: About to Give Up with HDRadio
    Aug 2006
    Columbus, OH
    I had a hard drive failure and reinstalled windows in a new drive along with RideRunner, etc. But know can not get HDRadio to work after new/fresh install.
    Here are the Specs:
    Windows 7 Professional 32 bits.
    RideRunner latest version 07-01-2010
    Radio: HDRadio Visteon HD-Zoom
    Cable: Mitch Serial Adapter
    Port: Built-in Com1 and also tested USB2Serial
    I can get the radio to work with Mitch radio app outside RR without a problem. But in RR I get the following error:
    Radio Support
    Radio not Configured
    Please run RRConfig and select the Radio you wish to use.
    I have tested with MoBo built in Serial port in Com 1 and it doesn't work on RR, however with Mitch ext app works fine.
    Also have tested with a USB2Serial and it does work with Mitch ext app but still no joy in RR.
    I have tried 3 different skins:
    DFX 4.0
    Reborn
    RR built-in Carwings Lite
    Neither one works, so the problem its coming from RR itself.
    I checked the RadioModules folder and it does have the HDRadio subfolder with the proper files:
    HDRadioComm.dll
    HDRadioRR.dll
    HDRadioRR.tlb
    MJSGAudio.dll
    Here's the rr.ini radio section:
    [Radio]
    radio=HDRadio
    allowallfreqs=true
    uselineinplugin=false
    lineinpar=line://title=Radio,srate=44100,bps=16,nch=2
    uselineinsingleinstance=false
    userbds=false
    RadioPort=7
    HDRadioType=Directed
    Please help. Thank you.
    Mike K.
    Jul 2006
    change RadioPort=7 to RadioPort=1, assuming you've put it back to com 1
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Also you need to make sure the radio .dll is registered. Go into this folder:
    \RideRunner\Plugins\MJS Gadgets\HDRadio\
    and double click "runme1st.cmd ".
    My Fiero Build Thread
    MySQL Error
    Oct 2004
    john, there is nothing like that
    hd radio isnt a plugin
    its a radio module...
    there is no runme1st.cmd...
    that was like 2 years ago
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2006
    Columbus, OH
    Quote Originally Posted by barnyard View Post
    Not the case I have used Radioport=1 when testing the HDradio with the built in Com1 and Radioport=7 when testing the HDradio with USB2Serial.
    Thank you anyway.
    MySQL Error
    Oct 2004
    and so, do u have it working yet?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2006
    Columbus, OH
    Quote Originally Posted by JohnWPB View Post
    John, as always your input so crucial pointing to the right direction.
    Quote Originally Posted by mitchjs View Post
    Mitch, that's exactly the problem. I believe you have a regression in the RideRunner installer sometime between the versions February 2010 and June 2010.
    I unistalled RR version July 2010 and installed June 2010 and always with the same bad result.
    However I noticed that either version (June or July 2010) only creates ONE HDRadio folder in the entire RideRunner install, that folder contains the files that I specified on my first post:
    HDRadioComm.dll
    HDRadioRR.dll
    HDRadioRR.tlb
    MJSGAudio.dll
    I did noticed that on both last installer versions (June & July) RideRunner installer before finishing it tries to register SiriusRadio, XMradio and HDradio. However after all install completes when I check the MJS Gadgets folder there's only the 2 following folders:
    SiriusRadio
    XMradio
    So basically the required HDRadio folder does not get created with the required .dll files under MJS Gadgets.
    What I did then was to clean out one more time, uninstalled again RideRunner and I tried a installer that I had working before hard drive broke. The installer is February 2010.
    After the install completed, I have now under the MJS Gadgets folder the 3 radios:
    HDradio
    SiriusRadio
    XMradio
    Checking the files inside under MJS Gadgets\HDRadio I have the files that John pointed out:
    HDRadioComm.dll
    HDRadioComm.tlb
    RegAsm.exe
    runme1st.cmd
    UnRegMe.cmd
    Also inside of the folder RadioModules\HDRadio i have only 1 file (not those 4 previously reported):
    HDRadioRR.dll
    With this installer from February 2010 my HDRadio works perfect.
    I believe that anyone doing a fresh install will run into the same problem as I did.
    I also believe that this was not noticed because once you do an upgrade from previous working version (like February 2010) to June or July 2010 it will still work because missing files still there and .dll still properly registered under Windows.
    Mike K.
    MySQL Error
    Oct 2004
    all that mjsgadets/hdradio is OLD OLD OLD OLD!!
    NONE OF THAT IS USED ANYMORE
    and NOT FOR MONTHS!!..
    all the newest installers, all have a clearn up code...
    but if you want, be smart, and do a UNINSTALL OF RIDERUNNER,
    then REINSTALL RIDERUNNER with 7/1/2010 installer
    these are the ONLY files used
    RideRunner/RadioModules/HDRadio/
    HDRadioComm.dll
    HDRadioRR.dll
    HDRadioRR.tlb
    MJSGAudio.dll
    if you mess with the old ones, ie try to reg them, HD Radio will not work
    UNINSTALL RideRunner, reinstall RideRunner (7/1/2010)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    mate the radios are modular..you will find all radio folders inside a folder called "RadioModules" in your RR path (program files...etc)
    Aug 2006
    Columbus, OH
    HDRadioComm.dll
    HDRadioRR.dll
    HDRadioRR.tlb
    MJSGAudio.dll
    Mitch, sorry but I believe I did not explain well or something. As I mentioned on my previous post I did:
    uninstall July 2010 completely making sure all was clean and installed it gain. NO GOOD.
    Then
    Unistalled July 2010 and cleaned up all and installed June 2010 - STILL NO GOOD.
    Then
    Uninstalled June 2010 and cleaned up all and installed February 2010. THIS ONE WORKS.
    Then
    Installed/Upgraded July 2010 "ON TOP" of February 2010 good working install and still works fine after July 2010 upgrade as expected/commented on my previous post.
    Believe me, I'm not pointing anything out to you or saying anything bad about your installer. I just like to say that IMHO there's a problem with the new installer that came sometime after February 2010. That Only can be noticed if you PERFORM A FRESH INSTALL.
  1. Replies: 41
    Last Post: 04-24-2007, 06:42 PM
  2. Any help you could give an old codger
    By warby in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-15-2006, 03:14 PM
  3. can you give me LCD shop on internet..?
    By helloman in forum General Hardware Discussion
    Last Post: 02-03-2004, 10:44 AM
  4. I hate to give this one away
    By keggers in forum LCD/Display
    Last Post: 02-27-2002, 11:53 PM
  5. Just about to give up on my 4x40
    Last Post: 11-27-2001, 02:52 AM
