Results 1 to 9 of 9
Thread: ride runner questions
    May 2010
    North Carolina USA
    I setup my ride runner system this week end.
    my question is
    1) I am running iguidance 3.0 and when i goto gps screen it goes full screen and i do not see the ride runner screen around it. what changes do i need to make to make this work?
    and
    2) when i play video it has a major blue tint to it. I have tried to use the gamma control panel
    and make adjustments in vlc player to no avail any ideas on how to correct this?
    3) can I have multiple webcam and select between them?
    thnks in advance for any help that is rendered
    system specs
    microxt motherboard 733mhz in a video on ip settop box
    512k ram
    tiny windows xp
    15 gig sd card (thru ide to sd adapter)
    radioshark am/fm (working on modifiying to connect to car antenna)
    logitech webcam
    rand mcnally serial gps reciever
    7 in screen (ripped from a non-working protable dvd player)
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by thebluearcher View Post
    my question is
    and
    system specs
    512k ram
    tiny windows xp
    logitech webcam
    What skin are you using?
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    May 2010
    North Carolina USA
    sorry
    I knew i should have added that
    carwings_dynamic_lite
    un-modified as of yet
    I will be moving around some of the buttons once I get everything running right
    MySQL Error
    Oct 2004
    WHAT ARE your gps nav settings...
    assuming you use rrconfig
    gps mode = external, ig native checked, GPS path is set to ig's exe
    and GPS window name is iGuidance
    rr.ini:
    gpsmode=2
    gpspath=C:\Program Files (x86)\iNav\iGuidance\iGuidanceUMPC.exe
    gpsname=iGuidance
    optional ig native stuff:
    [IG Native]
    ignative=true
    igautosw=true
    gpsonvoice=true
    pauseonvoice=false
    lastscreenswitchtime=0
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2010
    North Carolina USA
    video
    the video plays fine in vlc player outside of RR
    I will need to recheck my settings on the carpc as far as iguidance is concerened
    but i do not believe i put in the window name in rrconfig
    I will check when i get ready to leave work to day
    May 2010
    North Carolina USA
    iGuidance
    that took car of my iGuidance problem
    thanks a bunch for the help
    now if I could just get the people to stop looking like avatars when I play video
    and while I am at it
    What webcam do you find works best with road runner
    (the one I am using does not work well in day or night driving but works wonderfully at dusk)
    MySQL Error
    Oct 2004
    try another video player... like builtin
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    May 2010
    North Carolina USA
    Blue Tinted Video
    it make no difference what video player I use
    I get the blue tint inside of road runner but I do not get it outside of road runner
    I like vlc player as it supports more video codecs and on a 733 mhz system does not drag the video
    I have looked at taking the background screen out (it is the default blue smoke) but it had no effect on playback
    MySQL Error
    Oct 2004
    i cant tell you what it is then...
    use carwings
    use built in video
    use A DIFFERENT video!!!
    vlc is all software based codecs, so if your mb has hw acceleration, not a good choice
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Ride Runner is on break...
    By sgtpepperaut in forum Road Runner
    Last Post: 05-27-2010, 02:20 AM
  2. Ride Runner simple question
    By lefthooked in forum Software & Software Development
    Last Post: 03-16-2010, 02:44 PM
  3. Replies: 7
    Last Post: 03-02-2010, 05:44 PM
  4. altima 2005 newbie projet
    By FouFF in forum Worklogs
    Last Post: 04-02-2009, 09:27 PM
  5. Road Runner build, construct.beginner questions
    By hamid_sw in forum Software & Software Development
    Last Post: 09-04-2006, 09:43 AM
