Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: RR 08-05-2010 Release
    MySQL Error
    Oct 2004
    TAKE #2
    WOW August, summer is just flying by!
    Download Here
    **** UPDATED as of 3:34pm Eastern Standard Time *****
    I wanted to get this out to everyone...
    if you are running 8/1 - 8/3 builds of RR, please download 8/5
    course older than 8/1 should download 8/5
    this fixes a small bug introduced in the new radio_player skin handling, most people
    didnt even notice, but one fine RR user did, Dartman_71, my thanks to him
    Some Highlights:
    • "TRACKNAME" now updated continously when item is a URL and player supports tags (winamp)
    • USB Audio on resume lost control issue fixed.
    • Initial DVB Support - (DVBViewer plugin in the works)
    • radio_player.skin naming, now multiple radio devices can be supported in 1 skin
    • Enhancements to preloading of skins
    • new Events; ONMEDIAREMOVED & ONERRSCRNCLICK
    -mitch
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    08/5/10
    # Fixed all radio modules, corrected a minor issue on "radio_player.skin" compatability
    + "TRACKNAME" is now update continously on Players that support tags and when item is a URL type (contains "://")
    # Winamp.dll start up issue, when playing is already running...
    08/3/10
    # Fixed long outstanding bug for USB Audio Systems, not working after resume
    07/31/10
    # Weather plugin, fixed not setting a variable when weather was used in conjunction with the LOCATE cmd
    + Preloading screens expanded, now allows for a full preloading of a screen vs partial as was previous method (still default)
      (see NEW Settings.txt for details)
    + Preload screen debug logging
    + EVENT; "ONERRSCRNCLICK" when the ErrScrn is clicked
    07/25/10
    * Improvements to updatescreen process for current MP3TAG data
      (no longer need hidden playlists on screens with TAGxx labels on them, for them to be properly updated)
    07/24/10
    * Tweak to HDRADIO's "rsignal" label/slider, now returns hdsignal and fmsignal
    * Updated all radio modules to support the extended skin naming for radio_player
    07/14/10
    + Additional Radio Skin Support:
      examples; if Radio=HDRadio, RR will try to load "radio_player_hdradio.skin"
                if Radio=SiLabs, RR will try to load "radio_player_silabs.skin"
      This allows for multiple radio device support within a skin design.
      The skin has to be designed and named accordingly.
      If the radio specific skin isn't found, it will load "radio_player.skin"
    07/07/10
    + Inital DVB Support - SkinCommand; "DVB", translates to "LOAD;dvb.skin;DVB"
      label; ACTIVESOURCE  = "DVB", uservar; ACTIVESOURCEID = 9
    07/06/10
    + Event; "ONMEDIAREMOVED" when media is removed from "mediadrive"
    # Setting; "mediadrive=x"  x can be lower case now, "mediadrive=d"
    # ReloadSkin cmd followed by a load; cmd would show menu for a brief second before showing load;x screen
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Wow. Fast fix.
    But, now if I have any pre-load screens to load, RR wont go past where it loads them. If I take all the pre-load screens away, it works fine.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    ^+1
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
    MySQL Error
    Oct 2004
    fixed, sorry guys....
    you can slap us on this...
    we put the new installer on nisu, so just redownload
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Can I sling a couple of requests in here. (assuming they are not already available)
    1. iLists - Is it possible for this not to automatically start scrolling when you go back or enter the audio player if the song has changed while you were out of it?
    2. We have the IDLE command which can execute a command after a determined period, is there the possibility of having a command if there is mouse movement?
    MySQL Error
    Oct 2004
    #2, mouse... arnt most people using touch screens... getting past that the mouse could move alot im not sure u want to keep running the same command over and over
    maybe mouse move over a region? can i ask why?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    COOL !!!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mitchjs View Post
    I'm adding screensaver options to iDrive, now the IDLE command works fine for this. Currently the screensaver screen has one big button over it so if you have a TS you just hit it and it goes back, or use a keyboard with the ESC button.
    But my TS is not working at the moment and it's quite a reach to grab the keyboard, but the mouse ball is within easy reach. It also works by mouse click as well, b ut I thought make it just like a normal screensaver and mouse movement will end it.
    maybe have it so it has to be activated in a screen on load with a command in the skin. so it only works in that screen (.skin) and not across all the screens.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya, E... try using the "IDLEEND" event which is executed any time you move the mouse over an idle RR screen or any other activity with RR causing it to no longer be idle. Thats been there since '05
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. [REL] iGoBMW transparent
    By dan32500 in forum RR Released Skins
    Last Post: 02-27-2014, 12:25 PM
  2. RR 11/01/2009 Release
    By mitchjs in forum Road Runner
    Last Post: 11-28-2009, 08:11 AM
  3. RR 05-28-05.. Early Release..
    By guino in forum Road Runner
    Last Post: 06-04-2005, 08:36 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 12:27 PM
