Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: KeyTBL.ini doesn't work when video is fullscreen ?
    Aug 2004
    Germany
    I've come to the conclusion that the KeyTBL.ini isn't properly processed then video has switched to fullscreen (videoautohide enabled).
    When I open the video_player.skin the debug.txt shows, that all pressed keys from the KeyTBL.ini are recognized.
    After RR switches the video to fullscreen just the next keypress will be recognized, but none of the following (debug.txt contain any entries for the pressed keys).
    When I return from fullscreen (by moving the mouse) it works again.
    1. Can someone please confirm ?
    2. Could you guys add commands for manually going to fullscreen, returning from fullscreen and an indicator to check if video is fullscreen or not ? I'm working on a htpc skin. No mouse and touchscreen input there.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The intended logic is to "EXIT" full screen mode when any key is pressed, then once in non-full screen mode, the keys should work normally. If this is not what's happening, let us know -- The alternative for you would be to disable auto-hide and make a full screen .skin file which had all the space of the screen set for the video, then you could have a key to bring up a "MENU;video_menu.skin" which would have any options you may want to use.
    Ride Runner RR's Myspace
    Aug 2004
    Germany
    Sadly, it doesn't exit fullscreen on any key. But it does when moving the mouse.
    Will the zoom function work when auto-hide is disabled ?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Konrad View Post
    The zoom feature should work as long as you don't have nozoom=true in RR.INI.
    We need to fix the video player so that pressing any key will make the controls show OR make it accept the commands while in full screen. I'll take a look at that.
    Aug 2004
    Germany
    Thanks alot for looking into the problem .
    Aug 2010
    Hello
    We (Me and my Brother) are having some problem here.
    When Video controls hide, then they cant called back with any key from bmw monitor or keyboard. Only thing that works is moving mouse cursor.
    Our system is gonna work only through OEM (Original buttons that are install by car Manufacturer) buttons and no extra keyboards or mouses.
    So that is a bit problem for Us(Me and my Brother). Is there an easy fix coming soon.
    Best regards
    TimoA
    MySQL Error
    Oct 2004
    who is WE and US? and OEM?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Can you confirm your RR version ? I just tested keytbl.ini on video full screen here and it worked fine. Are you using Girder by any chance ?
    Aug 2010
    I think i am using latest rr (8/5/2010), and ibuscomm....
    Only thing that calls back controls is moving mouse cursor..
    Did you change anything and how in ibuscomm.ini or keytbl.ini
    With what key, or button does your controls return..
    Best
    TimoA
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Playing video file from HDD in fullscreen
    By djXternal in forum FrodoPlayer
    Last Post: 03-10-2005, 05:54 AM
  3. Replies: 2
    Last Post: 02-13-2005, 07:05 PM
  4. What do I need to make this LCD work with compoosite video?
    By pigseye in forum General Hardware Discussion
    Last Post: 02-19-2002, 09:36 PM
