Results 1 to 10 of 12
Thread: New Audio Source
    Low Bitrate rtgree01's Avatar
    Aug 2007
    STL
    New Audio Source
    So...
    I have worked on a new interface to talk to my car's OEM Sirius radio, steering wheel controls, and other stuff... I'm almost ready to use it in my system full time.
    I have written an extension that controls the Sirius radio and a corresponding skin for it. My problem is that RideRunner still thinks that it is in a different audio mode than Sirius. For example, I start listening to my MP3 collection, then go to my new Sirius skin... The TAGARTIST and TAGTITLE use information from both my extension and the Audio screen's information.
    How would I either "fake" RR into thinking the normal Sirius system is activated, or make a new type of Sirius system that RR recognizes?
    Thanks!
    MySQL Error
    Oct 2004
    since you say you wrote a plugin in, you can override TAGARTIST
    and return what you want, and have label nulled out, so RR wont process it
    just test if you should process it, set returnlabel, and LBL =""
    so rr doesnt process it
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2007
    STL
    I thought I was doing that....
    Here is a snippet of code for ReturnLabel. There are more labels that I "override" in the same manner. Did I forget something?
    Code:
    public string ReturnLabel(string LBL, string FMT)
    	string s = "";
    	if ((initd) && (active))
    		switch (LBL.ToLower())
                        case "trackname":
                        case "tagtitle":
                            s = radio.siriusTextLine[3].Substring(0, radio.siriusTextLine[3].IndexOf('\0'));
                            LBL = "";
                            break;
                        case "tagartist":
                            s = radio.siriusTextLine[4].Substring(0, radio.siriusTextLine[4].IndexOf('\0'));
                            LBL = "";
                            break;
    	return s;
    It looks like RR is appending to the label that I am filling.
    Aug 2007
    STL
    I also wanted to mention that the name of my skin file is not sirius.skin... Could that be the problem?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I advise you check the label with the skin too -- if you're using a standard skin the label code using may just be combined with something else making it seem like it has more data than what you returned. Your code appears to be right.. as long as initd and active are both true there's no reason why RR would ignore the returned information from your plugin -- I would suggest changing the label code for testing.. say "mytagtitle" instead of "tagtitle" then adjust the skin to test (just to see if your code is working correctly). There's no reason why it shouldn't work.
    Ride Runner RR's Myspace
    MySQL Error
    Oct 2004
    Quote Originally Posted by rtgree01 View Post
    Code:
    	string s = "";
                        case "trackname":
                        case "tagtitle":
                            LBL = "";
                            break;
                        case "tagartist":
                            LBL = "";
                            break;
    	return s;
    haha.... hahahahah
    hehehe, no one notices anything
    public string ReturnLabel(ref string LBL, ref string FMT)
    also add it to the interface
    string ReturnLabel(ref string LBL, string FMT);
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2007
    STL
    The "ref" must have been it...
    I'm going to have to check the original plugin example code... I don't think that I retyped any of this... Is it possible that the example has this bug?
    Thanks a bunch... another thing I'm going to need to check on is how the skin (Elite Wings) handles switching between audio sources. When going from audio to radio to my sirius, I'm going to have to figure out how/when to turn on and off my audio...
    Thanks a bunch... You guys are awesome at supporting the community!
    Ryan
    MySQL Error
    Oct 2004
    its not a "bug" its just whats needed
    skin names trigger audio in most cases
    becuase RR is SKIN based, not source based
    SETSOURCE could be your friend
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by mitchjs View Post
    How do you use SETSOURCE please.
    Can you give me an example ?
    MySQL Error
    Oct 2004
    setsource:
    from the documentation
    "SETSOURCE" - Sets the current Audio Input Source. Not available to switch to VIEWABLE inputs (i.e. video, dvd, tv).
    Not available while in "audio_player.skin", "audio_browser.skin", "rm_media.skin", "radio_player.skin", "sirius.skin" or "xm.skin" (for obvious reasons)
    Possible paramters are: RADIO, XM, SIRIUS, AUDIO
    Examples: "SETSOURCE;RADIO" (switches to radio without changing current screen)
    "SETSOURCE;AUDIO" (switches to mp3/music without changing current screen)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. What Windows Version do you use with RR ?
    By guino in forum Road Runner
    Last Post: 11-27-2010, 12:30 PM
  2. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  3. Unable to locate source of Audio Ground Loop / Noise
    By phuz in forum General Hardware Discussion
    Last Post: 05-25-2008, 12:01 PM
  4. multi source audio integration via amps
    By theonlykid in forum Car Audio
    Last Post: 11-21-2005, 07:42 PM
  5. Replies: 22
    Last Post: 01-03-2005, 04:44 PM
