Results 1 to 10 of 10
Thread: Issue with $rr.execute command
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile Issue with $rr.execute command
    I have an issue with an autoit script with several command in a same $rr.execute command.
    If i write:
    Code:
    $rr.execute("SETVOL;Winamp;10||SAY;"&$rr.getinfo("=$MESSAGEBODY$")&"||wait;0.5||SETVOL;Winamp;100")
    The volume is well set to 10, RR wait 0.5s , message is said and the vol is set to 100.
    My problem is that the third command don't wait that the second command (say message) is finished and the volume is not set to 100 but stay on the value 10.
    Where is the bug please ?
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    if you are writing a script, try to do all what you can using AI code, you can have youre own AI speech function is not hard at all, you dont need the wait command, if you want to add speech function to youre script, i can show you how to do it.
    May 2008
    Bordeaux, France
    Quote Originally Posted by EL CAMINO View Post
    Thanks, El Camino, i accept. If you have an example, i can try it
    EL CAMINO's Avatar
    Jul 2005
    try this little function.
    Attached Files Attached Files
    May 2008
    Bordeaux, France
    Cool El Camino.
    Big thanks
    May 2008
    Bordeaux, France
    El Camino,
    It is exactly that which I needed.
    Can you say me what is the language number for each language (for me , the french)
    May 2008
    Bordeaux, France
    I think that i have found a good link.
    How can i to test what voice is used by the PC without use the case option?
    language type number for sapi
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    You can just remove the case statements, and it will use what ever you have set up as the computers default voice.
    Here is an example script I just put together. I added the ability to check the Winamp volume, and then return it to where it was. If you were listening to something at 50%, spoke the message, you probably would not want it to go to 100% volume when it finished speaking
    The below script will:
    - Set Winamps volume to 50%
    - Speak the artist and title of the currently playing song
    - Return the Winamp volume to what it was before the script was ran
    PHP Code:
    $rr ObjCreate("RideRunner.SDK")
    SpeakSongInfo()
    Func SpeakSongInfo()
    $sapi ObjCreate("SAPI.SpVoice")
            if @
    error then
                MsgBox
    (0''"Please ensure that you have Sapi Installed")
                Exit
            EndIf
    $CurrentVolume $rr.getinfo ("VOL;Winamp")
    $rr.Execute("SetVol;Winamp;" "50")
    $artist $rr.getinfo ("tagartist")
    $Title $rr.getinfo ("tagtitle")
    $sapi.Speak ("You are listening to " $Title " By " $artist)
    $sapi ""
    $rr.Execute("SetVol;Winamp;" $CurrentVolume)
    EndFunc
    My Fiero Build Thread
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Ok, more tinkering here If you want to get a little fancier, you can ramp the volume down and back up again, for a smoother transition between the music and when it speaks.
    PHP Code:
    $rr
    Global
    $CurrentVolume
    Global $DropVolume
    Global $MyCount
    $DropVolume
    30 Winamp Volume to drop to when speaking
    $CurrentVolume
    RampVolumeDown()
    SpeakSongInfo()
    RampVolumeUp()
            if @
    error then
                MsgBox
                Exit
            EndIf
    $sapi ""
    EndFunc
    Func RampVolumeDown
        For
    $MyCount $CurrentVolume to $DropVolume step -4
            $rr
    .Execute("SetVol;Winamp;" $MyCount)
    Next
    EndFunc
    Func RampVolumeUp
        For
    $MyCount $DropVolume to $CurrentVolume
            $rr
    Next
    EndFunc
    May 2008
    Bordeaux, France
    Smile
    These two examples are very cool. I shall use it on my new gmail notifier version .
    Thanks again to El Camino and John
  1. Needed: BETA Testers for Google Earth Plugin
    By guino in forum RR Released Plugins
    Last Post: 08-24-2012, 03:25 PM
  2. Release new phoco integration preview
    By Robby BMW in forum Road Runner
    Last Post: 09-12-2009, 05:29 AM
  3. M4-ATX Power On Issue
    By PacketSniffer in forum Power Supplies
    Last Post: 04-24-2008, 10:00 PM
  4. .M3U issue "Play all" issue
    By Kimota in forum StreetDeck
    Last Post: 12-12-2007, 09:34 AM
  5. Video Full Screen On/Off issue - 1.1.0.9
    By Kimota in forum StreetDeck Bug Reports
    Last Post: 12-12-2007, 09:06 AM
