Results 1 to 8 of 8
Thread: Garmin 20x with gauge skin
    Newbie Hicotton02's Avatar
    Aug 2010
    Murrieta, California, United States
    So I am really new to this. I am trying to get my garmin gps to work with the gauges in the dfx 4. I got the garmin skin working. Xport seems that it is used generally. But it doesn't seem to work with the gps... Any ideas?
    Oct 2006
    Midlothian, VA
    If you got the bundle, it won't work that way. The software only sees the 20x if it hasn't been split by xport or garmin spanner. You need to have purchased the software without the GPS receiver to do it the way you're thinking of.
    Edit: Ops, forgot to add, it'll work but you will either have gauges or GPS. Not both at the same. I tried this as well when I first got it.
    Aug 2010
    Quote Originally Posted by ksgoh88 View Post
    Thanks for the post.
    So, do i have to do anything special to get the guages to work since its usb?
    Oct 2006
    Midlothian, VA
    You're going to have to use xport or garmin spanner to create the com port, and use that port number in the DFX4 config.
    Aug 2010
    i cant get either of those to work on this usb device.
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Hence the original response from the second post. The Garmin software needs to see the 20x directly without any split. Reading the software page, the Garmin Spanner is supposed to split the GPS18 software, and may work with other products, but Windows Vista is not supported.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    One of the reasons for the problems with the 20x is it is not just a GPS device, it is also a "key fob" that unlocks the software. There is a separate version of Garmin made to work with any GPS puck, In that case though, registration is required for the software.
    My Fiero Build Thread
    Oct 2006
    Midlothian, VA
    I've successfully split the 20x with xport as well as spanner. I did a lot of monkeying around with it to get it to work, but it wasn't hard by any means. I used it with the splitter for a day or two and found I never used it and always wanted the GPS, so I've stopped splitting it since.
  1. Replies: 145
    Last Post: 05-07-2011, 09:26 AM
  2. AllFlash Skin
    By potpeye in forum RR Skins
    Last Post: 07-21-2009, 10:57 AM
  3. TEKNIK3 - Concept Skin
    By Valheru in forum RR Skins
    Last Post: 05-27-2008, 01:26 PM
  4. HELP! Garmin Mobile PC GPS 20x USB receiver
    By lesterhung in forum GPS
    Last Post: 05-12-2008, 07:52 PM
  5. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 10:50 AM
