Results 1 to 10 of 10
Thread: Is there anyway to use xm from another soundcard?
    Oct 2005
    So I use a usb soundcard for my music output. I am wondering if I can connect my xm direct to the onboard soundcard's line input and use it and be able to have the music come through the usb soundcard? Anyone know? If so how can I do this? Thanks in advance
    MySQL Error
    Oct 2004
    YES... use the winamp line-in plugin
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Yes, that's quite simple.. I do that myself (the other way around, but same principle). Just install line-in plugin for winamp, open it's configuration and do the wizard thing on it specifying the card you want to record from.. once it adds the item to the playlist copy/paste the url item (linein://... info) into RRConfig's line in setting for XM after enabling it. When RR starts XM it will start the line in plugin with those settings and it should playback to your default audio card setup in winamp (same one playing mp3s) -- that should be all.
    Ride Runner RR's Myspace
    Oct 2005
    Quote Originally Posted by guino View Post
    I got this all set up and working, but it doesn't mute with the .net phone plugin.
    MySQL Error
    Oct 2004
    sounds likely
    im not familiar with the .net phone plugin, i have no idea what it does
    and how it mutes things
    i assume audio of the phone comes though pc, so it cant mute the master
    one of the problems here is rr's lack of complete audio management
    but you know, since your using the line in plugin, can u set up .net phone plugin to do a pause?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    .net phone plugin send pause or radiomute depending of source. Sounds like radiomute doesn't mute your XM radio and RR can't mute your onboard input line because your usb sound card is default device.
    MySQL Error
    Oct 2004
    pause should do i then... since he is using line in plugin
    does it know to send a pause for xm?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2009
    Finland
    Quote Originally Posted by mitchjs View Post
    I only know that pi send pause to music player and radiomute to HD and Silabs.
    Jul 2006
    Try using "PAUSE||WAIT;0.2||MOBILEPHONE_PICKUP" for your pickup button, and "MOBILEPHONE_HANGUP||WAIT;0.2||RESUME" for your hangup button. Works fine for me.
    Jul 2001
    I had to use audiorepeater with my usb dac and onboard line in to get it to pipe the audio through..... You can see how it did this in this post . Hope this helps - Manny
    http://www.mp3car.com/vbulletin/car-...ml#post1346219
  1. Replies: 42
    Last Post: 12-11-2009, 02:36 PM
  2. Replies: 1
    Last Post: 03-12-2008, 09:33 PM
  3. XM Radio & M10000 - Need another soundcard?
    By ACleanSC4 in forum Car Audio
    Last Post: 02-16-2007, 08:57 PM
  4. Got XM to work, then it took a dump
    By DuDs in forum StreetDeck
    Last Post: 05-06-2006, 05:42 PM
  5. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 08:49 PM
