Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 41 to 50 of 108
Thread: RR 10-04-2010 Release
  1. #41
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by marteline View Post
    What am I missing?
    RR doc: If the Slider is clicked/changed a "ONSLDVARNAME" event is triggered.
    my slider code:
    S01,220,380,142,10,545,75,35,30,H,01,"cursor.png", 5,"$GPXSLIDER1$",
    my skinfolder\exectbl.ini:
    "ONSLDGPXSLIDER1","RUN;$skinpath$SCRIPTS\RADAR\pla yfile.exe|proximity.wav"
    (already test in the skintool RUN;$skinpath$SCRIPTS\RADAR\playfile.exe|proximity .wav and it works)
    and no sound while slider moves... :-(
    You can also to use the RR command PLAYSOUND
    "ONSLDGPXSLIDER1","PLAYSOUND;$SKINPATH$SCRIPTS\RAD AR\Alarm.wav"
  2. #42
    MySQL Error
    Oct 2004
    because, i didnt code it that way...
    IFVAR came to me in a dream by the way
    not to mention, it can work with strings
    IFVAR;myvar=hello;dotrue;dofalse
    its ment for simple....
    use EVAL for today
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #43
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by pierrotm777 View Post
    Indeed, I am using it right now, this is the only way that not crash because of the multiples occurrences...
    I am just struggling with a way to make it play faster when get closer to the target and play slowler when go far...
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  4. #44
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Just for information, Pierrot changes the software to send the ONSLDGPXSLIDER1 and itīs exec'd without being change by user. So, about the "ONSLDxxx", is not necessary the "human touch" to fire the event.
    Incorrect.
    Pierrot has added a command called ONSLDGPXSLIDER1 which is controlled by his plugin/script and therefore different to the ONSLIDERxxxx commands provided by RR.
  5. #45
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by mitchjs View Post
    not to mention, it can work with strings...
    Quote Originally Posted by Enforcer View Post
    Incorrect.
    Ok Guys, whathever works,stop yelling at me!!!
    The ONSLDGPXSLIDER1 is working for me and the IFVAR works great with EVAL for < and >...
    And I will be quiet now, I promisse!
  6. #46
    MySQL Error
    Oct 2004
    naw... u dont have to be quiet, if u need help... ask
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #47
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    as mitch says no need to be quit , there's always alot of teasing around here , usually between us UK guy's and the US guys, but its just that friendly teaseing,,,,
    sometimes us old user forget what its like to be a newbie so to speak , and there are alot of users that don't understand RR but use it , good for you for getting stuck in mate , ask away
    we are all here to help
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  8. #48
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Thanks guys!
  9. #49
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    I Know that when you say I can ask you donīt mean right now, but...
    Here is a problem where I am stucked:
    this event works pretty well and play sound when slider act:
    Code:
    "ONSLDGPXSLIDER1","EVAL;SLDSTATUS;<($GPXSLIDER1$;$PREVSLD$)||SETVAR;PREVSLD;$GPXSLIDER1$||IFVAR;SLDSTATUS=1;PlayWav;$SKINPATH$Scripts\RADAR\slider.wav"
    I try to replace for this one to play different sounds for 3 ranges:
    Code:
    "ONSLDGPXSLIDER1","EVAL;SLDSTATUS;<($GPXSLIDER1$;$PREVSLD$)||SETVAR;PREVSLD;$GPXSLIDER1$||IFVAR;SLDSTATUS=1;EVAL;RANGE_FAR;>($GPXSLIDER1$;40000)||EVAL;RANGE_MID;>($GPXSLIDER1$;15000)||
    EVAL;RANGE_MID;>($RANGE_MID$;$RANGE_FAR$)||EVAL;RANGE_CLO;<($GPXSLIDER1$;15000)||IFVAR;RANGE_CLO=1;PlayWav;$SKINPATH$Scripts\RADAR\CLOSE.wav||IFVAR;RANGE_MID=1;PlayWav;$SKINPATH$Scripts
    \RADAR\MID.wav||IFVAR;RANGE_FAR=1;PlayWav;$SKINPATH$Scripts\RADAR\FAR.wav"
    All playwavīs are tested and also the EVALīs, I think that is related to the expression after the first IFVAR, I also tryed IFVAR;SLDSTATUS=1;(mycode) but I guess I canīt use ()...
    Can you help me?
  10. #50
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Nevermind again,
    I just use some IFVARīs inside another IFVARīs and itīs working now:
    the full result:
    Code:
    "ONSLDGPXSLIDER1","EVAL;SLDSTATUS;<($GPXSLIDER1$;$PREVSLD$)||EVAL;RANGE_FAR;>($GPXSLIDER1$;40000)||EVAL;RANGE_MID;>($GPXSLIDER1$;15000)||EVAL;RANGE_MID;>($RANGE_MID$;$RANGE_FAR$)||EVAL;RANGE_CLO;<($GPXSLIDER1$;15000)||IFVAR;SLDSTATUS=1;IFVAR;RANGE_CLO=1;PlayWav;$SKINPATH$Scripts\RADAR\CLOSE.wav||IFVAR;SLDSTATUS=1;IFVAR;RANGE_MID=1;PlayWav;$SKINPATH$Scripts\RADAR\MID.wav||IFVAR;SLDSTATUS=1;IFVAR;RANGE_FAR=1;PlayWav;$SKINPATH$Scripts\RADAR\FAR.wav||SETVAR;PREVSLD;$GPXSLIDER1$"
    thanks again!
  1. RR 08-05-2010 Release
    By mitchjs in forum Road Runner
    Last Post: 08-31-2010, 02:22 PM
  2. Replies: 1
    Last Post: 11-02-2009, 09:22 PM
  3. XM works in Timetrax, not RR
    By bruha in forum Road Runner
    Last Post: 12-30-2006, 08:38 AM
  4. Next release (BETA 10) delayed
    By skippy76 in forum Road Runner
    Last Post: 11-24-2005, 11:29 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
