Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 54
Thread: RideRunner Profile Mode and you
  1. #31
    MySQL Error
    Oct 2004
    i do have code to determine if in profile mode, but its for INNO setup
    not hard to do... check regkey...
    then %userdocs%\RideRunner is the base path
    in raw terms:
    %USERPROFILE%\My Documents\RideRunner
    each installer has some keyword to get there
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #32
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Good point
    However this work great unless whoever installed RR decided to install to a directory other than RideRunner. (I know it's unlikely, but it's possible)
    Hence it would be nice if there was a definitive path in the reg.
  3. #33
    Oct 2005
    Albuquerque, NM
    Background Directory
    I'm not sure if my change to profile mode caused this, but when using the RRConfig Utility to change the skin background the dropdown stops at the directory level not allowing a selection of the actual background file. My recollection is that before profile mode, the RRConfig Utility allowed you to select the actual image file. Using current RideRunner version 05/01/11 and RRConfig v1.0.2.22
  4. #34
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    RRConfig only allows you to set the Background folder path.
    You set the background in the skin itself (al least where a skin has designed it so)
  5. #35
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Which is correct, there are few if any skins made recently that don't allow background changes from within the skin
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #36
    Oct 2005
    Albuquerque, NM
    Thanks Enforcer, Blue;
    rr.ini to have "background=**path to background images**" (as set by rrconfig).
    skins.ini to have "background=**image name**" (in local skin directory).
  7. #37
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Enforcer View Post
    If I was using the installer program you are using maybe that I would use that code, but I am using NSIS.
    However it did point me in the right direction once I had done a legacy to profile conversion.
    And it showed me that I can only find out that we are running in profile mode, great, but it doesn't tell me where the files have been moved to.
    I agree with E. This is becomming an issue for me too. I converted my phone app to profile mode and most of the issues being raised are due to the ini file not being in the correct place due to profile mode and the installer not knowing.
    So first how do i know RR's in profile mode and second how do I know where to install stuff without a definitive directory location?
  8. #38
    MySQL Error
    Oct 2004
    very easy....
    check for rr.ini in userdoc\RideRunner\Config
    else
    you get from the registry where rr is installed
    then check for rr.ini at that location
    now you know
    sample inno code:
    for getting the CORE DATA PATH... since your a plugin... you want more
    prob many other simple ways to do it...
    attached is one of my plugins installer
    INNO Setup...
    Code:
    // Get DATA Path, based on Profile Mode
    function DataPath(p: String): String;
    begin
    	// look for rr.ini?
    	if FileExists(ExpandConstant('{userdocs}\RideRunner\Config\rr.ini')) then
    	begin
    		if DirExists(ExpandConstant('{userdocs}\RideRunner')) then
    			Result := ExpandConstant('{userdocs}\RideRunner')
    		else
    			Result := ExpandConstant('{reg:HKLM\Software\RideRunner,Path|{pf}\RideRunner}')
    	end
    	else
    end;
    anyway, its not hard...
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #39
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Still would like to see registry entries created either by RR's installer or by RR itself when running for
    RR's path & RR's data path.
    It would take any guesswork out when a user has a strange install path. (Not looking at pierrotm777 at all)
  10. #40
    MySQL Error
    Oct 2004
    yea. good idea... all you have to do is ask...
    technically RR not allowed to write to registy!
    not HKLM at least
    i see what i can do in installer
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Relationship Mode 1 and Mode 06 (Request On-Board Monitoring Test Results) in KWP200
    By proyectanteATE in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-23-2011, 05:56 PM
  2. Profile Mode oddball discussion
    By justchat_1 in forum Road Runner
    Last Post: 10-08-2010, 12:10 PM
  3. Profile Mode
    By spamminator in forum Road Runner
    Last Post: 08-09-2010, 06:30 PM
  4. Does XM mode operate as 'RADIO' mode
    By rjoek in forum Road Runner
    Last Post: 07-07-2005, 11:18 AM
  5. Search Mode / Jump Mode
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 05:48 PM
