Page 1 of 6 123456 LastLast
Results 1 to 10 of 54
Thread: RideRunner Profile Mode and you
    MySQL Error
    Oct 2004
    Profile Mode:
    What is it, or where are my files....
    come with me over the next few posts, together we'll learn about it.
    RR for quite some time, prob more than a year, has a built in file manager. This file manager
    keeps track of where internal files should be on ones PC. File examples: rr.ini, resume.ini, skins, plugins, and many temp files
    all thoes pestky .ini files....
    in PROFILE MODE, they are all located in
    My Documents\Ride Runner
    here is an example: (windows 7)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    As you can see files are now organized
    lets look at specific folders:
    Backgrounds:
    This is where all those wonderful backgrounds go, when stored here all skins can use them
    thanks to DFX5 i now how alot
    Cache:
    This is where RR will store its temporary files. Examples: tagcache.ini, xmcache.ini, rrpl.m3u8, resume.ini...
    Config:
    This is where RR will store/access its configuration files. Examples: rr.ini, KeyTBL.ini, xmfavs.ini, ExecTBL.ini (global)...
    Launch:
    MixerPresets:
    Plugins:
    This is NOT where you put plugins, they still go in the correct places, ie global; C:\Program Files\RideRunner\Plugins\...
    this folder is what the plugin should be using to store its localized data.
    I'll say this now, NO USER DATA should ever be stored in the Program Files Path. One this is a UAC violation, and two
    just a pain to keep user specific data away from programs... dont want to get into a debate on this, its always been a rule by Microsoft
    just not really inforced. Typically we dont run into problems, becuase we tend to have single users on car pcs. But windows OS was written
    to have many users on one pc, and have complete isolation of data.
    Skins:
    yep this is where the skins go...
    example:
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    more folders:
    SkinTools:
    Ok, i know its a plugin, but its so special, aka wonderful, it got its own data directory.
    Next I will post a TOOL that will switch you to profile mode, it basically will copy files from RR's folder into
    a new tree like above.
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    RR Legacy to Profile mover
    This program copies the data found in the RR root, it has been tested quite a bit
    but it may miss something, and you might have to manually handle it
    since the skin moves, you might have to double check skin settings in rr.ini
    for a long time, there is no real need for a full path to a skin ie
    [Skins]
    skinpath=Carwings_Dynamic_Lite
    nightskin=Carwings_Dynamic_Lite
    work perfectly fine, RR's File manager will use the defualt locations of the skin folder
    a full path will work too... but when moving from legacy to profile... just double check it
    the tool will attempt to fix it on its own...
    the tool may even need more tweaking
    but i think i got it right
    when complete a log will be created, detailed to what happend
    and if we need to work though any issues, im sure ill want to see it
    snip
    Code:
    10/7/2010 10:06:27 PM: Started: UserProfilePath = C:\Documents and Settings\mitchjs\My Documents\RideRunner
    10/7/2010 10:06:27 PM: Started: RRPath = C:\Program Files\RideRunner
    10/7/2010 10:06:54 PM: Directory Move: C:\Program Files\RideRunner\Backgrounds to C:\Documents and Settings\mitchjs\My Documents\RideRunner\Backgrounds
    10/7/2010 10:06:54 PM: Directory Move: C:\Program Files\RideRunner\MixerPresets to C:\Documents and Settings\mitchjs\My Documents\RideRunner\MixerPresets
    10/7/2010 10:06:54 PM: Directory Move: C:\Program Files\RideRunner\Launch to C:\Documents and Settings\mitchjs\My Documents\RideRunner\Launch
    10/7/2010 10:06:54 PM: Directory Move: C:\Program Files\RideRunner\Skins to C:\Documents and Settings\mitchjs\My Documents\RideRunner\Skins
    10/7/2010 10:06:54 PM: Fixed background= in RR.ini; To set path, Click ---> to
    10/7/2010 10:06:54 PM: Fixed SKIN_PATH= in Resume.ini; C:\Documents and Settings\mitchjs\My Documents\RideRunner\Skins\CDL_DAB\ to CDL_DAB
    10/7/2010 10:06:54 PM: Registry: for installer set ProfileMode = 1
    10/7/2010 10:06:54 PM: Profile mode file / directory moves are complete
    10/7/2010 10:06:54 PM: !! Remember to check ExecTbl.ini and skins for paths that use $RRPATH$ in error !!
    im always around and can help anyone who needs it...
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    well i have been useing this script since mitch made it up some time back when i 1st started testing for mitch , it works great , moves all files from a standard rr install into this profile mode, granted you will still need to edit a few settings after useing this script , but thats not a big deal atall
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    same here, using profile mode since mitch told me about it.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    same here..using profile mode for over a year now..works very nice indeed
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mitchjs View Post
    since the skin moves, you might have to double check skin settings in rr.ini...
    What does this need to run, and where does it need to be?
    I have just tried to run this on a clean XP Pro SP3 install with the latest RideRunner installed and it just gives a ' . . . . has encountered a problem and needs to close' error.
    I am logged in as a Domain Admin which is also a member of Local Admins so it can't be a rights issue.
    I have tried it both inside and outside of the RideRunner folder
    looking into what would be sent to MS I see a system.missingmethodexception
    MySQL Error
    Oct 2004
    since ur using XP,
    do you have .net 2.0(minium) framework?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I installed the latest RR (01/11/10) and selected the venice 5 Radio module which asked for .NET 2.0 to be installed, it linked to the download when it recognised that it wasn't installed and then installed.
    So my guess is yes.
  1. Relationship Mode 1 and Mode 06 (Request On-Board Monitoring Test Results) in KWP200
    By proyectanteATE in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-23-2011, 05:56 PM
  2. Profile Mode oddball discussion
    By justchat_1 in forum Road Runner
    Last Post: 10-08-2010, 12:10 PM
  3. Profile Mode
    By spamminator in forum Road Runner
    Last Post: 08-09-2010, 06:30 PM
  4. Does XM mode operate as 'RADIO' mode
    By rjoek in forum Road Runner
    Last Post: 07-07-2005, 11:18 AM
  5. Search Mode / Jump Mode
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 05:48 PM
