Results 1 to 6 of 6
Thread: Problem with RR
    Newbie Angel106's Avatar
    Oct 2009
    Problem with RR
    The version of May onwards I am having the same problem .
    You can see the album art of focus.
    RR I installed it on XP and Seven and reflected the same problem .
    I enclose photos.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    RR pulls the first graphic image it finds.
    Some tagging or players create a hidden low quality image and sometimes this can be the first image alphabetically.
    MySQL Error
    Oct 2004
    and rr will go upwards in folders, and keep looking for a image file
    (annoying at times, but sometimes needed)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Oct 2009
    Thumbs up Problem solved with RR
    I found the solution by installing RR Plugin Mp3Art taken from the link: RR 10-04-2010 Release .
    Now you can clearly see.
    Thank you all for your help.
    Jul 2009
    That didn't work for me. What I did was set the album art to folder.jpg and renamed every .jpg I had in each album folder to folder.jpg and it worked beautifully.
    '05 Magnum RT
    CarPC coming soon. Hopefully end of 2010.
    Parts left to buy-
    Monitor, Bybyte frame, Axxess hook up, Sheet metal for double din case.
    Oct 2009
    Quote Originally Posted by SpyderZ15 View Post
    It seems to me that after installing the Plugin, RR is no longer used the jpg file but it takes the image from the music, that I gave it through Windows Media Player.
    I just want to do other tests to be sure.
    As soon as I know something you do know.
    Hello Angel106 ...................
  1. Replies: 0
    Last Post: 09-12-2009, 05:56 AM
  2. Switching between RR and copilot
    By CombatCQB in forum Road Runner
    Last Post: 01-26-2009, 05:27 PM
  3. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 12:20 PM
