Results 1 to 2 of 2
Thread: Weird audio issue involving Mobilephone.Net
    Jul 2006
    I wasnít exactly sure where to post this as itís an audio issue, but may or may not be related to RR/Mobilephone.Net
    My setup:
    Andrea Superbeam bundle with USB-SA adapter into my MOBO (MSI K9N6GM) with onboard Realtek ALC888. Iím using the USB-SA as the default playback device directly to a JL Audio CL-RLC(volume control), then to my amps. I have an XM Direct & a Visteon HDZ300 going through a UAS into the line in on the MOBO utilizing the WinAmp line-in plugin. This setup allows echo cancellation for hands-free use, and still allows the XM & Radio tuners to function properly.
    XPSP3 Running 10-4 RideRunner, Winamp 5.58, DFX 5.0.3
    The problem:
    After ending a phone call (Mobilephone.NET plugin), my audio sounds really distorted/muffled. I think the Andrea software may be trying to do noise cancellation on the output, but I canít confirm this. Any ideas on what the problem may be?
    A possible work-around Iím considering is going straight from the UAS and using a splitter to combine the XM & radio with the output from the USB-SA where it goes into the CL-RLC. Will this cause any issues with Ďbackfeedingí signals from the tuners into the USB-SA & vice versa? Any other issues Iím not thinking about?
    Jul 2006
    Well, after thinking about my workaround some more I realized that I won't be able to mute radio using my steering wheel controls, so that's out. What could possibly be causing the problem?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Weird sound issue
    By TheKingPlaza in forum Road Runner
    Last Post: 03-10-2006, 11:47 AM
  3. Weird Inverter Issue
    By Noodleman in forum Power Supplies
    Last Post: 04-05-2005, 05:25 AM
  4. XM Direct Audio Issue
    By beckkl in forum General Hardware Discussion
    Last Post: 01-18-2005, 11:14 AM
