Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 60
Thread: *** New Product *** MJS Gadgets USB-IO-1
  1. #21
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Was thinking Mitch, maybe a way to pass a command for a time limit on a relay, say something like Trigger1On;5 would trigger relay #1 on for 5 seconds. This would be useful mostly for controlling windows and such. Trigger2On;.25 would trigger the relay on for .25 seconds, for power door locks. I am sure there are other uses, but with the time passed to the relay, it's open to a lot of possibilities.
    It would be far cleaner than Trigger1On||Wait;5||Trigger1Off
    If No parameter is sent, then just toggle on / off as directed.
    My Fiero Build Thread
  2. #22
    MySQL Error
    Oct 2004
    sure possible... i look to add timed pulses in a revision, right now i want to get these out to the public :0
    for power windows, i would not directly control a window... use a power window module
    i would try to only do roll up or down, not anything inbetween, just to ugly on a touch screen (specially while driving)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #23
    Dec 2010
    Twilight Zone
    Anyone make one of these for Windows? I'm getting something similar, and more commercialized, for controlling LED warning lights for my vehicle, but would much rather have a cheaper, simpler solution.
  4. #24
    MySQL Error
    Oct 2004
    hu?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #25
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by mitchjs View Post
    Touchscreen??? I was thinking more on the lines of just saying "Put the windows up"
    I think he may mean for windows, EA, no front end required. Possibly by sending commands from a batch file / command line or something?
  6. #26
    MySQL Error
    Oct 2004
    hehe... maybe...
    but thats why i have a .dll for it, you can use it in your own applications if one wants to
    yes, for put the windows up, you should NOT drive a relay directly for that, a simple directed electronics window module (530t) will do, then the USB-IO-1 would tell that to roll em up
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #27
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Just came up with another great Idea for this! I added a circuit for a low fuel warning to my Fiero, as it was not a factory option. It lights up a "Low Fuel" light in the dash. (The circuit has a potentiometer that lets you set the gallons left in the tank before it alerts you, I am setting it at 2 gallons, roughly a 50 mile warning).
    I am going to split the positive side from that light to one of the inputs on the IO ports. This way, when the car gets low on fuel, it can speak "Fuel level low" or something, and with a pop-up have the opportunity to navigate to a gas station, if you ignore the pop-up it will just go away in a few seconds.
    Lots of cool stuff can be done with this device
  8. #28
    Dec 2008
    yeah john but thats why carpc's is just about the best hobby ever. its challenging but not impossible, the things you can do is limitless and ever changing, and you can actually use it to make life easier every single day. most hobbies are either money pits or time wasters. carpc's eats money and time, but it also improves the quality of your life sometimes.
  9. #29
    Aug 2005
    Can you use this device to sense 12V (ACC) and turn on/off a relay?
    Does the software have the ability to auto trigger a relay on startup or do you have to manually click a button in the GUI each time?
    ---------- Post added at 07:44 PM ---------- Previous post was at 07:37 PM ----------
    Ohh and one more..
    CarPC gets turned on, device turns on with USB power. Does the relay turn on straight away or does it need to wait for the software to communicate aka windows loaded up.
    Reason I ask is, I want to trigger a remote wire for the amps. It should turn on every boot but only once windows is up so I don't get the "thump". I also want it to turn that relay off when it looses ACC on the digital input.
    I know the Fusion Brain can do what I want but the are out of stock everywhere, so hoping this can.
  10. #30
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    You can just use a plain old relay with no software to do that
  1. MJS Gadgets UAS - comming soon to carpc near you
    By mitchjs in forum Road Runner
    Last Post: 08-14-2012, 05:24 PM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  3. Lillput USB problems
    By the_big_1 in forum LCD/Display
    Last Post: 11-22-2008, 12:00 PM
  4. *NEW* USB 16 Isolated High Current Digital Outputs, IOPoint-USB
    By bibaja_llc in forum Hardware Development
    Last Post: 07-04-2007, 10:47 PM
  5. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
