Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 60
Thread: *** New Product *** MJS Gadgets USB-IO-1
  1. #41
    Aug 2005
    Yea I'm ordering one or two this week.. I think the only thing that would be nice for me is if the relays were bigger than 1A. Other than that looks great.
  2. #42
    MySQL Error
    Oct 2004
    they 1amp @ 24v (so 2 at 12)... but 1amp is enough for 95% of the jobs, if you need more, like to drive a motor, you should have it drive an automotive relay
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #43
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i picked up a pack of 10 relays and sockets for $19 from a stateside supplier on ebay. there are 5 packs out there too.
    i have 4 of the mjs usb-io's (may be adding another one) and they are working flawlessly in riderunner with the joycon exr connected. (no compatibility issues)
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  4. #44
    Aug 2005
    Quote Originally Posted by mitchjs View Post
    Ohh that's good to know. I wanted to run two monitors @ 1A each off one relay. Looks like I can do that after all.
  5. #45
    Aug 2005
    This may be a stupid question..
    Say I take +12V from my DC-DC PSU and feed into one of the common ports, then out to my monitor. I would connect the monitor ground wire back to the ground at my DC-DC PSU correct?
  6. #46
    MySQL Error
    Oct 2004
    sounds right...
    12v in on relay #1 common, relay #1 out goes to monitor
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #47
    Aug 2005
    sounds right...
    But what about the monitor ground? Is it automatically grounded back to the DC-DC through the USB port (since it is also powering my CarPC)?
  8. #48
    MySQL Error
    Oct 2004
    where ever u get ground from now...
    i dont know anything about this monitor, but if it has power wires, one is ground...
    if there is isolation from the power supply, use its ground, else any ground will do...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #49
    Aug 2005
    Nowhere.. New install that hasn't made it too the car yet.
    I'm just powering my MiniTouch 700 monitors off my Opus DC-DC powering my CarPC as it is more reliable power. I'm just unclear on the ground.
    I don't know if I should ground the monitors to chassis or back to a ground wire on the DC-DC, which in turn is grounded to chassis.
  10. #50
    MySQL Error
    Oct 2004
    ok, if the opus isnt isolated, then its ground is chassis, therefore, just ground the monitors to chassis
    m
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. MJS Gadgets UAS - comming soon to carpc near you
    By mitchjs in forum Road Runner
    Last Post: 08-14-2012, 05:24 PM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  3. Lillput USB problems
    By the_big_1 in forum LCD/Display
    Last Post: 11-22-2008, 12:00 PM
  4. *NEW* USB 16 Isolated High Current Digital Outputs, IOPoint-USB
    By bibaja_llc in forum Hardware Development
    Last Post: 07-04-2007, 10:47 PM
  5. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
